edward Posted June 26, 2016 Report Posted June 26, 2016 When a pattern calls for a 2 3/4 clock, and you want to down size to 1 3/8 , what percentage would you use, does anyone know off hand, just curious. edward Quote
Iguanadon Posted June 26, 2016 Report Posted June 26, 2016 (edited) I'm showing my math so someone can correct me if I'm wrong. 2 3/4 = 2 6/8 and that is double 1 3/8, so the answer is 50% Edited June 26, 2016 by Iguanadon Birchbark 1 Quote
jerry1939 Posted June 26, 2016 Report Posted June 26, 2016 (edited) Re: your second fraction. 3 divided by 8 = .375. Plus the one means you want to resize to 1.375 Your pattern is 2.75 inches. 1.375 divided by 2.75 = 50%, your desired ratio. To double check it your answer is correct take the desired size of 1.375 and multiply it by 2. The result is 2 3/4 (2,75), your current pattern size. Hope this helps friend. jerry Edited June 26, 2016 by jerry1939 Quote
edward Posted June 27, 2016 Author Report Posted June 27, 2016 Thanks guys, will give it a try. edward Quote
amazingkevin Posted June 27, 2016 Report Posted June 27, 2016 I'm showing my math so someone can correct me if I'm wrong. 2 3/4 = 2 6/8 and that is double 1 3/8, so the answer is 50% Re: your second fraction. 3 divided by 8 = .375. Plus the one means you want to resize to 1.375 Your pattern is 2.75 inches. 1.375 divided by 2.75 = 50%, your desired ratio. To double check it your answer is correct take the desired size of 1.375 and multiply it by 2. The result is 2 3/4 (2,75), your current pattern size. Hope this helps friend. jerry You numbers guys astound me Quote
Lucky2 Posted June 27, 2016 Report Posted June 27, 2016 Wow, what a bunch of mathematicians here. Len Quote
Jim Finn Posted June 28, 2016 Report Posted June 28, 2016 I would just open it in "paint' and resize and resize until I get what I need. I do this all the time. I do it 10% at a time to start. Quote
CharleyL Posted June 28, 2016 Report Posted June 28, 2016 I do this the headache free and math free way for me. I load the image into Photoshop and re-size it to the dimension that I want, then print it. I'm very experienced with Photoshop, so that is my first choice for this. It can be done with many other software packages too, especially with those having layer capability.. For Photoshop I would just create a circle of the right size on a new layer, position and center it it over the clock circle in the base layer, and then transform the base image under the circle until the cut-out for the clock matched the circle in the layer above it, then hide the circle layer (for possible re-use) and print the base image. No math or experimentation required (and no headache). My old HP Laserjet 1100 laser printer was kept as a pattern printer for making scroll saw and carving patterns because it has proven to do better than my newer inkjet printers. Cartridges are getting cheaper for it too, down to about $8 each with free shipping the last time that I ordered some. Charley Quote
