GrampaJim Posted June 29, 2016 Report Posted June 29, 2016 This is a Steve Good pattern I pulled into Inkscape and changed the 2nd line of words. It is my first time cutting cedar and really like it. To make it easier (because I am lazy ), I enlarged it a bunch from the original size, which made it a little to fragile. There is a crack on one of the letters at the top, but with a little effort I was able to fix it so it is almost undetectable. neptun, MTCowpoke22 and amazingkevin 3 Quote
Clayton717 Posted June 29, 2016 Report Posted June 29, 2016 nice cutting. i like cutting cedar too. Quote
Scrolling Steve Posted June 29, 2016 Report Posted June 29, 2016 Very nice work !.....Cedar can get even more fragile over time. Quote
amazingkevin Posted June 29, 2016 Report Posted June 29, 2016 This is a Steve Good pattern I pulled into Inkscape and changed the 2nd line of words. It is my first time cutting cedar and really like it. To make it easier (because I am lazy ), I enlarged it a bunch from the original size, which made it a little to fragile. There is a crack on one of the letters at the top, but with a little effort I was able to fix it so it is almost undetectable. I have bad luck cutting cedar .Too brittle.I spent 3 times as long repairing the project as it took to cut it.I see you did good,lucky you! Quote
rjR Posted June 29, 2016 Report Posted June 29, 2016 #1. GREAT CUTTING! #2. I like cedar; but do not use it for any project that will tend to have small structure areas. #3. That will be a fragile piece unless made from a super good plywood. Quote
rdatelle Posted June 29, 2016 Report Posted June 29, 2016 Nice cutting Jim. I like cedar to. I'm doing a lot of compound cutting out of cedar. Yours came out good though. Don't you just hate it when a small piece will breat when your almost done. Glad you were able to fix it. Quote
Fish Posted June 29, 2016 Report Posted June 29, 2016 Great work. I really like cedar too. I've found you can seal it with mineral oil and after it dries the cedar smell comes back. Quote
DWSUDEKUM Posted June 29, 2016 Report Posted June 29, 2016 Very nicely done Jim. That came out great. Thanks for sharing this with us. DW Quote
Lucky2 Posted June 30, 2016 Report Posted June 30, 2016 Nicely done Jim, with it being the size and style that it is, it would be fragile. Len Quote
wombatie Posted June 30, 2016 Report Posted June 30, 2016 Nice cutting Jim. Glad you managed to save it. Marg Quote
daveww1 Posted June 30, 2016 Report Posted June 30, 2016 very nicely done, thank you for sharing Quote
