woodduck Posted July 8, 2016 Report Posted July 8, 2016 (edited) I stacked cut these two out of 4mm. Marine Ply & used both spiral & flat blades although the spirals especially did not last long before they were blunt so went through a lot of blades,the marine ply must be a lot harder than the Baltic Birch that a lot of you people use.Added a bit of colour to these for something a bit different,hope you like. Cheers Peter. Edited July 9, 2016 by woodduck Smudger, lawson56, New Guy and 2 others 5 Quote
spirithorse Posted July 8, 2016 Report Posted July 8, 2016 Nice work, Peter, I've alwaysliked that pattern and will probably have to search for it in my paper files to cut it sometime in the future. Thanks for sharing and God Bless! woodduck 1 Quote
wombatie Posted July 8, 2016 Report Posted July 8, 2016 Peter I love the added color, really brings them to life. Well done. Marg woodduck 1 Quote
lawson56 Posted July 8, 2016 Report Posted July 8, 2016 I agree,the color does bring it to life.The Yellow is my Favorite.Awesome work. woodduck 1 Quote
newfie Posted July 8, 2016 Report Posted July 8, 2016 Beautiful work peter is that pattern available somewhere i know a friend of mine would like to have that piece. thanks for sharing woodduck 1 Quote
Scrolling Steve Posted July 8, 2016 Report Posted July 8, 2016 Wonderful work on a great Charles Dearing patten !......Like the use of color ! woodduck 1 Quote
woodduck Posted July 8, 2016 Author Report Posted July 8, 2016 Beautiful work peter is that pattern available somewhere i know a friend of mine would like to have that piece. thanks for sharing Yes it is a Charles Dearing pattern. Quote
newfie Posted July 8, 2016 Report Posted July 8, 2016 Yes it is a Charles Dearing pattern.ok thanks woodduck 1 Quote
Denny Knappen Posted July 8, 2016 Report Posted July 8, 2016 Well done on a beautiful pattern. Yes, the colors make it stand out. woodduck 1 Quote
DWSUDEKUM Posted July 8, 2016 Report Posted July 8, 2016 Very very nicely cut Peter. That came out fantastic. Thanks for sharing this with us. DW woodduck 1 Quote
amazingkevin Posted July 8, 2016 Report Posted July 8, 2016 I agree,the color does bring it to life.The Yellow is my Favorite.Awesome work. My favorite color too! woodduck and lawson56 2 Quote
amazingkevin Posted July 8, 2016 Report Posted July 8, 2016 I stacked cut these two out of 4mm. Marine Ply & used both spiral & flat blades although the spirals especially did not last long before they were blunt so went through a lot of blades,the marine ply must be a lot harder than the Baltic Birch that a lot of you chaps use.Added a bit of colour to these for something a bit different,hope you like. Cheers Peter. I wish i could get motivated to do the whole series of Indians that are available.Very highly collectable,You just don't see them for sale anywhere.Great looking portrait ! woodduck 1 Quote
ike Posted July 8, 2016 Report Posted July 8, 2016 Those are great cutting I like the one with Rec feather tips best. IKE woodduck 1 Quote
Dave Monk Posted July 9, 2016 Report Posted July 9, 2016 Very nice job. Love the color. dave woodduck 1 Quote
Vott1 Posted July 9, 2016 Report Posted July 9, 2016 I also really like what you did with the colors. It's one of the things often missing in scroll work. And Charles Dearing is one of my favorites. woodduck 1 Quote
dgman Posted July 9, 2016 Report Posted July 9, 2016 Great work Peter! The main difference between Baltic birch plywood and marine grade plywood I's the glues use to sandwich the layers. On BB plywood they use a water soluble glue. On marine grade plywood they use a waterproof epoxy type glue which is much harder on blades. woodduck 1 Quote
woodduck Posted July 9, 2016 Author Report Posted July 9, 2016 Great work Peter! The main difference between Baltic birch plywood and marine grade plywood I's the glues use to sandwich the layers. On BB plywood they use a water soluble glue. On marine grade plywood they use a waterproof epoxy type glue which is much harder on blades. Thank you for the explanation it makes sense.I use the marine ply because it seems to be of better quality & less voids. Quote
daveww1 Posted July 9, 2016 Report Posted July 9, 2016 very nice, thank you for sharing woodduck 1 Quote
Lucky2 Posted July 10, 2016 Report Posted July 10, 2016 Thank you for the explanation it makes sense.I use the marine ply because it seems to be of better quality & less voids. I don't know where you're getting your BB plywood, I've yet to see a void in BB plywood and I've used a lot of it over the years. I have seen #2 BB with small voids or poor patchwork, but, I never buy #2 grade. There is different grades, are you sure your getting #1 grade 2fs? Len woodduck 1 Quote
woodduck Posted July 10, 2016 Author Report Posted July 10, 2016 Len being from Australia we do not get the same type of plywood you get I suspect the plywood we get is some sort of pine. I will check to see what grade it is. Quote
kywoodmaster Posted July 11, 2016 Report Posted July 11, 2016 Those look great. Love the color. woodduck 1 Quote
Ron Johnson Posted July 11, 2016 Report Posted July 11, 2016 Excellent cutting of a fine pattern and nicely framed. woodduck 1 Quote
rdatelle Posted July 11, 2016 Report Posted July 11, 2016 Nice cutting Peter and good color choice. woodduck 1 Quote
