Here is a picture that you had requested a few days ago from another post. My apologies for taking so long posting it.
As I said in the other post about blade selection, I use this blade for compound cutting. Works great on the birdhouse ornaments!!
Buddy buddy I noticed that on scroll reverse blades only 2 0r 3 reverse teeth actually touch the wood,is this a design mistake?I'm waiting on cash so i can scroll my butt off.I just have baby blades now. thanks Gonzo.
Oops let's try this
Kevin, the Pegus blades are available at Ben's Scroll Saw .com.
Erv
I'll check them out,thanks ,your the best!
Kevin,
Bushton Mfg Hawk woodworking Sells some styles and sizes. You can also order from Grobet USA as they are the Mfr of Pegas blades.
Fredfret
Wichita Ks
Kool i'll look into them,thanks friend!
The Pegas #5 Modified Geometry blade is my "Go-TO" blade! The one I use the most for cutting 3/4" thick puzzles from walnut, cherry, padauk, locust, etc. I switched some time ago from Flying Dutchman blades (tried em all) because of the superiority of the Pegas blades for my application.
For my colored puzzles which I dip in food coloring I will use the #7 MG Pegas blade because I want a bigger kerf due to the wood swelling.
Here is where I order my Pegas blades:
http://www.dndsawbladesonline.com/
bb
