northampton scroller Posted July 13, 2016 Report Posted July 13, 2016 Hi Everyone. I have managed to acquire some 0.9mm brass plate. I have some Antilope No 3 metal cutting blades,would these be suitable,hope you are all enjoying the better weather and getting your saw out into the garden...cheers Jim Quote
fredfret Posted July 13, 2016 Report Posted July 13, 2016 2/0 or almost any jewler blade. Your material is only about 1/32 in thick. I'm not familiar with the blade you mentioned so I can't tell if that will work well on the brass by itself. I would sandwich it between 1 layers of 1/8 or 1/4 plywood and use almost any blade you want. Fredfret Wichita, ks amazingkevin and Scrolling Steve 2 Quote
hotshot Posted July 14, 2016 Report Posted July 14, 2016 (edited) It doesn't hurt to try what you have, but I agree with fredfret that 2/0 Jewelers are the way to go. On amazon, search for Pike brand as they are they best I've found for this type of blade. If you are not cutting high detail, you could go a little bigger (1/0 is bigger than 2/0), but I would stay with Jewelers regardless. ----------Randy Edited July 14, 2016 by hotshot amazingkevin and northampton scroller 2 Quote
amazingkevin Posted July 14, 2016 Report Posted July 14, 2016 (edited) Good advice for our friend 2/0 or almost any jewler blade. Your material is only about 1/32 in thick. I'm not familiar with the blade you mentioned so I can't tell if that will work well on the brass by itself. I would sandwich it between 1 layers of 1/8 or 1/4 plywood and use almost any blade you want.FredfretWichita, ks Fredfret!Good advice for our friend Edited July 14, 2016 by amazingkevin northampton scroller 1 Quote
amazingkevin Posted July 14, 2016 Report Posted July 14, 2016 It doesn't hurt to try what you have, but I agree with fredfret that 2/0 Jewelers are the way to go. On amazon, search for Pike brand as they are they best I've found for this type of blade. If you are not cutting high detail, you could go a little bigger (1/0 is bigger than 2/0), but I would stay with Jewelers regardless. ----------Randy Thanks Randy ,I'll check them out too! northampton scroller 1 Quote
