Has anyone tried or use the Pegas brand of blades?
If so you honest thoughts. They are less inexpensive (cheaper) than Olson or Flying Dutchman but there again a stamped blade is a stamped blade is it not?
Mark
I have tried them once.  i purchased a sample pack a while back.  Tried a few and was not impressed, but they cut, did their job.  It was not enough of a test to say much good or bad.  The problem for me is I have used FD blades so long now that I would have to get use to any other brand, by using them for sometime.  I do not know if all "stamped" blades are the same, but I doubt they are.  The way they are process, material used, and tolerances must play some part in it.  I do know that some I have had that I bought at the big box stores, were not the same, last as long or cut as clean as FD blades.
I have bought a pack a while back and wasn't impressed with them,
they were-only about 10 cent cheaper per blade then olson's blades. you can't buy much for a dime.
Edited by ike
Pegas modified geometry #3 and modified geometry #5 are my go to blades. I seem to have better control using them vs the Flying Dutchman, (though I do like FD blades). The modified geometry #5 works very well for me when compound cutting. I use both the #3 and #5 when doing fret work.
I stock up on them when Woodcraft runs their coupons.
It was about 1o cent a blade but the Pegas didn't last nearly as long as the Olson's,.. I go thru about 3 doz. a week $3.60 saved with Pegas blades. Not worth it to me,
IKE
I got them when Bens workshop was going and I used the FD puzzle blades for years for making ornaments and small things. I tried the pegas blades of about the same size and I find them a lot better because they are skip tooth with the blades more open to avoid the clumping up with junk wood. I make most of my stuff with 1/8 bb plywood. I then ordered a gross of them from somewhere else.  The name I can't remember right now. But I am impressed
nrscroller
I was amazed at the difference in prices on some blades.  Most seem to prefer the FD. I could get a dozen FD #3 spirals for around 3.00 a dozen on line (before shipping).  My local hardware store carries Olsen and #3 spirals were 8.99 a dozen.  I guess it depends on how long they last and is the price reflective of quality or supply and demand.  (I know that's probably a drop in the bucket for most people, but around here it's groceries)
WOW!!!! $8.99/dozen at your local hardware store? I don't know where in Kansas you're at, boss, but sounds to me like you should do some online research, & find a different place to buy your blades. Even in an emergency, I wouldn't pay that! I live in NW Kansas, & buy all my blades from wooden teddy bear. Have for years. I get most of my patterns from them, too. I use FD & Olson blades both, & have my preferences of each. I keep around 30 different types & sizes of blades on hand. Every project requires more than one type & size of blade, usually. You'll find the deeper you get into scrolling, the more prefrances you'll acquire. Pegas blades has a few sizes & types that are ok, but not my favorites. Most of my projects are 3/8" to 1/2" material. My go to blade is the FD #3 polar blade, or the Olson #4 skip tooth. Fretwork & such I'll use the FD #1 blade. They cut a long time, & give no issues. I use rough sawn lumber in all my projects, too. Which has a tendancy to work blades harder. Even in cherry, which burns easily, I don't have that issue. It's your money, friend.
Edited by SCROLLSAW703
I live in Junction City.  The hardware store carries about 5 different plain blades and 2 pin.  They range from 4.99 to 8.99.  The first three employees there didn't even know what a scroll saw was... they had to call in the assistant manager. lol  I really do need to do some online research.
The only Pegas  blades that I will use are the #5 & #7 modified geometry and than only for compound cutting. For me they work much better than any of the skip tooth blades I have tried. They seem to go around curves much easier than other types and not taper that I have trouble with FD ultras.  Just my opinion, take it for what its worth.
Erv
Debinoz,
Bushton mfr carries many different size blades including Olson, FD and Pegas/pike. Lookup Hawkwoodworking. Or come to the State fair they will be just outside the Domestic Arts building with saws, blades etc. I am NOT employed by them just a supporter of good people producing a good product here in the US.
Fredfret
Wichita, Ks
