breadstick Posted August 30, 2016 Report Posted August 30, 2016 I tried to find the original post, but I can't seem to. Someone here said you should always seal the back of your pieces because unsealed wood would warp and distort the piece. How much should you seal the back? I put three coats of poly on the front of the piece I finished last night, but not sure how much to use on the back. Since you can't see it, would one heavy coat on the back suffice? Quote
hawkeye10 Posted August 30, 2016 Report Posted August 30, 2016 I would put two coats of clear. If the backer board is ply then you don't have to do it but it might look better if you do. Quote
WayneMahler Posted August 30, 2016 Report Posted August 30, 2016 Depends on the piece I am working on. If the backer shows I finish the same as the top. If it hidden usually 2 light coats of finish to protect it. Quote
breadstick Posted August 30, 2016 Author Report Posted August 30, 2016 Thanks. 2 coats of poly isn't too much more effort. Sounds stable to me. Quote
dgman Posted August 30, 2016 Report Posted August 30, 2016 I always apply the same amount of coats to top, bottom and back. Just the woodworker in me. Quote
NC Scroller Posted August 31, 2016 Report Posted August 31, 2016 I have made hundreds of pieces with backers and I have never sealed the back of the backer. Well I did a couple times because I painted/finished the wrong side but that is another story. I have NEVER had an issue. But then again I use plywood (mostly 1/8" Baltic Birch) for all my backers. Quote
Lucky2 Posted August 31, 2016 Report Posted August 31, 2016 As long as it has one coating of sealer, that's all that's needed. You don't need the back to be as good looking as the front, you just need it sealed so that it can't absorb moisture. Len Quote
amazingkevin Posted August 31, 2016 Report Posted August 31, 2016 I tried to find the original post, but I can't seem to. Someone here said you should always seal the back of your pieces because unsealed wood would warp and distort the piece. How much should you seal the back? I put three coats of poly on the front of the piece I finished last night, but not sure how much to use on the back. Since you can't see it, would one heavy coat on the back suffice? Sounds good to me .Your just keeping the elements from the wood,air water,moisture, Quote
