I purchased a used Purple Canadian Excalibur 21S.  The seller said they did not have a manual for that older version.  I was hoping someone on here could point me to the right one or provide a copy if you had one.  I found two versions on line through manuallibs but not sure either of them applies to this particular model.  I am attaching copies of both of them here (if it works) in case someone needs one of them or can look at and tell me if one of them is the one for the older purple model.  I question it because the model number on the one I got says EX21S and these have different numbers/letters after the 21 model number.  Thanks for any help anyone can provide.
505078_manual.pdf
ctex21ce.pdf
Edited to add I bought the saw from Seyco and Ray @ Seyco told me the following in regards to these two manuals I did find and on trying to find the correct one.
"Manuals specific to the purple saw are extinct. The ones you have found are close but are for the European versions of the saws manufactured by General International for Carbatec in Australia."
Maybe they can be of use at some point to someone who has one of these from Australia but not the manual.  ;)
I will of course check with JGR - I was interested in the purple one having used one at JGR's class.  This one has some modifications to to though - have to get the stand put together and see how its going to work.
However, in the interim, if anyone has a manual they can share or link to one it would be greatly appreciated as my class with JGR is not for another 5-6 weeks or so.
Edited by meflick
Thanks.  Have to get the stand together and the machine on it to give it a whirl.  Still looking for the correct manual as noted in my edit of my original post if anyone has one they can share in some way.
