lawson56 Posted September 1, 2016 Report Posted September 1, 2016 I have recently switched over to thinner wood 1/4 inch for my cutting's, I have some blades that were given to me,I don't know what kind they are.but they do a Fantastic job.I know they are #5.they are thinner.possibly #3.What do you Fellow Villager's use for wood this thin.I am doing all my cutting with BB Plywood. Quote
fredfret Posted September 1, 2016 Report Posted September 1, 2016 I use Fd#3 reverse #1,and 2/0 plus 2/0 new spirals for 1/4 BB ply. I cut puzzles with Superior puzzle blades and 1/4 BB Ply. Fredfret Wichita, Ks Quote
Scrolling Steve Posted September 1, 2016 Report Posted September 1, 2016 I use FD 2/0 and 3/0 spirals and #3 ultra reverse in 1/4 BB all the time ...No reason the #5 blades wouldn't work fine! Quote
LarryEA Posted September 1, 2016 Report Posted September 1, 2016 I don't understand (#3's and # 5's) since there are more than one type of (#3's and # 5's). I use a #2CT that is an (.026 x .013 with 20TPI ) to cut 1/4 inch wood. or a 2R (.029 x 012 with 20-14rev TPI) THese are Olson blades Quote
LarryEA Posted September 1, 2016 Report Posted September 1, 2016 http://www.scrollsaw...w-blade-survey/ http://www.scrollsaw...of-blade-usage/ Quote
Bill WIlson Posted September 1, 2016 Report Posted September 1, 2016 Are we talking about straight blades? If so, depending on the detail and intricacy of the pattern, I will use a #2, #2/0 reverse tooth Olson or maybe a #1 FD/UR. For me, anything larger is more aggressive than necessary for 1/4" thick material. Spirals are a different matter. Quote
Denny Knappen Posted September 1, 2016 Report Posted September 1, 2016 I use FR UR #1 of FD Spiral #2/0 depending on the project. Quote
Lucky2 Posted September 2, 2016 Report Posted September 2, 2016 Bobby, for 1/4" bb plywood, I usually use a #3UR blade from the Flying Dutchman. Len Quote
amazingkevin Posted September 2, 2016 Report Posted September 2, 2016 #5 scroll reverse is my choice for 1/4" wood,high details #3 Quote
Ron Johnson Posted September 2, 2016 Report Posted September 2, 2016 If the blades you're using straight, cutting ¼" BB with a #3 or #5 is generally a good choice. I usually go to a #5 automatically when cutting ¼", ½" and or ¾". Quote
lawson56 Posted September 2, 2016 Author Report Posted September 2, 2016 Thanks Guys, It would seem that #3 is the most go to blade for 1/4 inch wood I will have to order me some this weekend after my Labor Day sale.Which I hope is a Great one Thanks again for all your help I will try to let you know how it turns out. Quote
NC Scroller Posted September 3, 2016 Report Posted September 3, 2016 I seldom cut a single piece of 1/4" wood. I like to stack cut 3 -4 pieces depending on the pattern. My go to blade is a #5 FD UR but depending on the pattern and even the part I am cutting I might switch to a #1 or #3 FD UR or even a #1 or #2/0 spiral. I also use Olsen #5 PGT at times Point being don't lock yourself into one blade size, brand or type. Experiment and see what works for you. Sorcier 1 Quote
