Hi all,
I have been looking at getting some more blades, alot of the ones that are sold seem to be 127mm but the ones that came with mine I believe are 133mm, will the 127mm blades fit or do I need to choose the same size?
I presume I have some leeway as you have to tension the blades.
Thanks,
I think the 127mm will be just fine. I have the Dewalt 788 saw and even a little shorter than 127mm would work. You could also measure by sticking a thin piece of cardboard in there and marking it then measuring it after you take it out. In reality I don't think you will have a problem.
PS- Welcome to a great place to learn and have fun.   :)
Hi all,
Thanks,
I've wore out chinese saws so much i had to cut !/4" off the end of the blade so it would fit.
