stu Posted September 10, 2016 Report Posted September 10, 2016 I have a delta 2 knife 12 1\2 in planer have to order replacement blades at $75 but after experimenting the Rigid 13in blades work after cutting 1\4in off each end pins line up perfect and that's at $50 for a set of 3 so $100 I have 3 sets of knifes guess I keep the $70 planer hope this helps someone save $$$ Stu amazingkevin 1 Quote
hawkeye10 Posted September 10, 2016 Report Posted September 10, 2016 I have a delta 2 knife 12 1\2 in planer have to order replacement blades at $75 but after experimenting the Rigid 13in blades work after cutting 1\4in off each end pins line up perfect and that's at $50 for a set of 3 so $100 I have 3 sets of knifes guess I keep the $70 planer hope this helps someone save $$$ Stu Stu how do you cut the blades off? Quote
WayneMahler Posted September 10, 2016 Report Posted September 10, 2016 Stu I have the Ridgid Planer. I ordered my replacement knives off Amazon for around $30. Might want to see if you can find yours up there. Quote
Bubbala Posted September 10, 2016 Report Posted September 10, 2016 An angle grinder with a thin cut off abrasive blade should do it hawkeye10 1 Quote
amazingkevin Posted September 10, 2016 Report Posted September 10, 2016 I have a delta 2 knife 12 1\2 in planer have to order replacement blades at $75 but after experimenting the Rigid 13in blades work after cutting 1\4in off each end pins line up perfect and that's at $50 for a set of 3 so $100 I have 3 sets of knifes guess I keep the $70 planer hope this helps someone save $$$ Stu I have a ryobe 13.5.Been using it a lot lately.I;m learning as i go.I can run 6" long wood thu it. I have nicks in the blades but you sand anyway so i'll keep going. Quote
Lucky2 Posted September 10, 2016 Report Posted September 10, 2016 Stu, thanks for this info, we're always looking for ways to save money. Len Quote
JTTHECLOCKMAN Posted September 10, 2016 Report Posted September 10, 2016 Have an older Delta model myself. You can easily hone those blades. Many years ago I bought one of those honing devices for jointer and planer blades and it works quite well. Quote
stu Posted September 10, 2016 Author Report Posted September 10, 2016 I got the saw filer at work to cut them but the blades are so small you could cut with a hacksaw, have honed them but yellow cedar burls really hard on blades one set just for that,with exchange I think $50 Canadian is $30 U.S. Stu Quote
