I thought I would share the way I glue and clamp mitered sides for a box. I'm sure there are a lot of ways. This is pretty basic for many of you. If you have a better way please share it with me. dave
1. Make sure each piece is the exact same width. I use my thickness planer.
2. Each adjacent side the exact same length using a stop.
3. Lay against straight edge point to point.
4. Use painters tape to tape together.
5. Turn over and put glue in the V.
6. Fold up.
6. Fold up.
I believe you just taught an old dog a new trick,Thanks
Thanks for sharing Dave.  I have been doing that also.  Just an added tip.  After you have glued and wrapped the tape on the final corner & set it upright, take a ruler and make sure the diagonal measurements are identical.  In case there is a slight difference, use a bar clamp or some heavy objects to force the "long" side to where it should be.
jerry
This system works well.  I have used it for, one of a kind, boxes.  I make box frames similar to this 20-30 at a time and I have made a jig/frame to hold the four sides upright.  I apply glue as is shown in the photos, but then just set the four sides together and "clamp" this assembly with four rubber bands. No tape.
Dan, Mitered corners are not hard at all.
1. Good blade
2. Miter saw fence at a right angle to the base
3. Perfect 45 angle
4. Material thickness and width on all pieces identical
5. Use a stop so all pieces are the identical lengthd
