I've been using Flying Dutchman Ultra Reverse blades in sizes 1-7 for a long time now. I've been using Olson 2/0R blades because up until now FD UR didn't come in a 2/0. I just ordered more FD UR blades and noticed they now have UR in 2/0. Has anybody used the UR 2/0 blades yet? I had tried the FD SR 2/0 blades and could not control them. I ended up giving them away, so before I order some, I'd like to know if they do ok.
I'll be interested in the replies to this question, as well.  I had a similar experience with FD SR 2/0 blades in the past and have exclusively used Olson 2/0 since.  I recently tried some #1 FDUR blades and like them a lot.  If the 2/0 size is as good as the others, then I'll definitely have to try them out.
I use FD PS # 2/0 and FD PS # 1  for a few years now, mostly for 1/8" BB and have also used them on 1/4"  1/2" Oak for small lettering in signs. Seems to work for me, haven't tried the others as of yet. Just my opinion.  edward
The only 2/0 flat blade I ever tried was a FD don't remember the exact one but could not control it even with the slowest speed, also had the same problem with #1 blade. The #1 turned would not turn to the right regardless of what I did. About that time the UR became available and problem solved. I later found out that the #1 had a defect that caused the problem. It will be interesting to see how the new UR 2/0 will do. I have enough blades to carry me through to the new year and than place an order and for sure get a few of the new one.
Erv
I've use plenty of mikes blades ,no complaints,I didn't pay attention to the blades your asking about sorry
I have just received UR 2 Blades from Scroller Mag,I,m pretty sure,there UR 2 They have like 20 some odd teeth going one way and about 14 teeth going the other,if this is the blade your talking about,I have had pretty good luck with them.I have had them for about a week,and have gone thru 3 or 4 blades. :D
Bought a dozen to try out a month or so ago.  Worked well on thin stock.  Not something I would use a lot, as most of my cutting is Intarsia, but I cut a fretwork cross the other day and had no major issues. other than having to slow down my saw speed.
