I posted a while back that I was going to try Elmer's preposition spray glue if you are going to cut it today or you don't get finished  it isn't too great. The second day the pattern came up as I was cutting. Elmer's stick glue saved the day. I now have Krylon  . spray glue I know it will hold.IKE
Elmer's is the only repositionable glue that that I use, I've never had an issue with it. The only glue that has given me any trouble so far is 3M77, for me, it was a nightmare to use.
Len
I used 3m medium grade spray. If I have not properly covered the pattern, I may get some lifting when I am using regular paper. If the pattern is more complex, I will use card stock paper. Even if it lifts, it's easy to tack back down.
