Don,
I find all the different brands to be about the same. The bigest issue is how long it sat on the shelf at the store. All can be thinned with water and are easy to clean up. I only buy the small containers and only the colors I need for the project.
Good luck
Fredfret
Wichita, Ks
Hi Don:
You can do much better than Walmart paint
As mentioned above, if you're only doing bits and pieces
than you can get by
Americana
Delta Ceramcoat
Folk Art
Apple Barrel
are some that I've used over the years with great success
Normally buy the 2oz bottles but for the colors I use more than others I buy the 8oz. bottles
Fab4
  On 9/29/2016 at 12:14 PM, hawkeye10 said:
For those of you that use craft paint on some of your projects, what is the best brand to use? I have been using Apple Barrel brand I get at Walmart but I was wondering if I can do better.
I've painted thousands of palms,birds,waves,coconuts with Winsor newton gallery acrylic paints,pre mixed ready to brush,Loved it
  On 9/30/2016 at 4:24 PM, MrsN said:
I use Americana paint. I believe it is made by deco-art.
The paint brush you use will really help. Spend a bit more on the brushes and you will see great results.
Mrs N can you suggest some good brushes? I know nothing about them. Thanks
