Jamie B Posted October 2, 2016 Report Share Posted October 2, 2016 What do people use and recommend for fixing patterns to blanks? At the moment I just use normal paper type glue (prit stick etc) I know this may not be the best and the paper can get a little wet! Plus it can be a pain to remove. Look forward to your suggestions, particularly for products available in the UK. Jamie Quote Link to comment Share on other sites More sharing options...
DonR Posted October 2, 2016 Report Share Posted October 2, 2016 Jamie, This has been discussed many times here. Here is a link to one of those discussions. If you do a search, you will find many more. I use any good brand of repositionable spray adhesive. Most of them work well and can be easily removed with a little mineral spirits. http://www.scrollsawvillage.com/topic/20302-fixing-patterns/?hl=+attach%20+patterns Don R Quote Link to comment Share on other sites More sharing options...
Jamie B Posted October 2, 2016 Author Report Share Posted October 2, 2016 Thanks Don. Maybe a little lazy of me not to search first...😎 Quote Link to comment Share on other sites More sharing options...
MrsN Posted October 3, 2016 Report Share Posted October 3, 2016 I had to look up what a Pritt Stick was, but it turns out I use that type of glue. I cover the wood in painters tape, then stick the pattern to the tape with regular glue sticks. It is quick and I can do it inside, no getting high! Winters are too long to have to go outside every time I start a new pattern. If you ask 10 scrollers how they do it, you will get at least 12 answers. Katie Sparkey, GrampaJim and amazingkevin 3 Quote Link to comment Share on other sites More sharing options...
crupiea Posted October 3, 2016 Report Share Posted October 3, 2016 I use a very light coat of spray glue and I mean light,. maybe 1 second for the entire pattern. if you put more, it will stick too much and be hard to take off and require sanding. its a bit of an art but once you figure it out, you wont go back. It says right on the can how to do it so it can repotisioned. use those instructions. If the spray on the paper looks wet at all, its way too much. Quote Link to comment Share on other sites More sharing options...
Rob Posted October 3, 2016 Report Share Posted October 3, 2016 Don, Mineral spirits is white spirit to you and I. Rob Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted October 3, 2016 Report Share Posted October 3, 2016 Jamie, I use a spray adhesive, I find it to be easy to use and it holds the pattern in place really well. With all types the different ways to attach a pattern to wood, it would be advisable that you do some trial and error work. After all, what works for me, may not work for you. Len Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted October 3, 2016 Report Share Posted October 3, 2016 Jamie, This has been discussed many times here. Here is a link to one of those discussions. If you do a search, you will find many more. I use any good brand of repositionable spray adhesive. Most of them work well and can be easily removed with a little mineral spirits. http://www.scrollsawvillage.com/topic/20302-fixing-patterns/?hl=+attach%20+patterns Don R I quickly draw a thin line of elmers school glue on the pieces that need it to hold good,it doesn't dry so fast an it's in a pinpoint tip bottle Quote Link to comment Share on other sites More sharing options...
Jamie B Posted October 3, 2016 Author Report Share Posted October 3, 2016 Thanks guys. I presume painters tape is masking tape. Lots of ideas to try to.dind out what works for me. Cheers Jamie SCROLLSAW703 1 Quote Link to comment Share on other sites More sharing options...
lawson56 Posted October 3, 2016 Report Share Posted October 3, 2016 I myself use carbon paper,Tape the pattern down,then trace it.You can still find Carbon paper at Office Depot.This is what I do. Quote Link to comment Share on other sites More sharing options...
Rolf Posted October 4, 2016 Report Share Posted October 4, 2016 (edited) I put painters tape or REMOVABLE contact paper on the wood first then attach the pattern to that. I currently use a Xyron machine to put the adhesive on my patterns. No mess no fumes and very fast. Easy to remove when done. Time is my issue not cost etc. The only time I would use graphite paper is for a wood burning design. Edited October 4, 2016 by Rolf Quote Link to comment Share on other sites More sharing options...
Sparkey Posted October 4, 2016 Report Share Posted October 4, 2016 Thanks guys. I presume painters tape is masking tape. Lots of ideas to try to.dind out what works for me. Cheers Jamie Painters tape is like masking tape but not as sticky. It will come off a lot easier. Painters tape is blue in the USA. I use clear packaging tape and some two sided very thin tape or spray glue over that. WayneMahler 1 Quote Link to comment Share on other sites More sharing options...
