I cannot remember !!!!....I know that a couple of you fine folks have said you use the FD penguin silver blades...I am cutting a bunch of the little bird houses (3d) ...do you use the the silver or the silver reverse ???...Help and old guy out,....Thanks, Steve .
Well, I can't comment directly on the penguin silver blades as I have never used them, but generally speaking, I would suggest that the silver might be a better choice over the silver reverse for compound cutting.  Reverse tooth blades don't clear the chips and sawdust as well as non-reverse tooth blades, especially in the thicker material necessary for the birdhouses.  You also don't have as much concern with tearout on the bottom with compound cutting, so the need for reverse teeth isn't really there.
No truer statement made,thank you for your expertise!
When i had the blades of choice i'd use flying dutchmans scroll reverse #5-7-9.  I could run thu a cord of wood in no time
