Those that are into scrolling vinyl records, what are you using to display them??  Did you make a base of some sort or are you hanging on the wall some way. Are you making into clocks and again how are you displaying??  Any photos would be a great help. Thanks in advance.
That would work when using those type hangers with the motors. I have now seen some people just take a block of wood and cut a slot on an angle half way through and place the record in that. You could glue it in also. I was thinking maybe that method or may try to use an easel type picture frame holder such as the one I make for my Irish Claddagh clocks. Will see when I start doing these. Maybe someone else has some ideas. Thanks
The more I read about some of these record cuttings the more I read about people laser cutting them. It would be understandable for some of the ones I have seen are so detail oriented it would be tough to cut with a scroll saw safely.
Again the more I read the go to method seems to use a cnc rotary cutter with a 1/16" mill end bit. Must be able to write code for the pattern which leaves me out.
Edited by JTTHECLOCKMAN
