rljohn56 Posted October 14, 2016 Report Posted October 14, 2016 i need some tips or ideas for hanging some of my projects. Since most of my projects that i want to hang is made from 1/4 inch baltic birch plywood i'm having a hard time finding screws short enough that they won't protrude to the other side when mounting hanging hardware. I'm leery of adhesive to stick the hardware to the wood for fear of it giving up and all that i worked for crashing to the ground. any suggestions will be appreciated. thanks, ray Quote
hawkeye10 Posted October 14, 2016 Report Posted October 14, 2016 Glue a piece of wood on the back and screw your hanger to that. Lucky2 1 Quote
LarryEA Posted October 14, 2016 Report Posted October 14, 2016 Heavy subject for me. Lots of ways............I use Sawtooth hangers and short nails superglued in Phantom Scroller and Lucky2 2 Quote
dgman Posted October 14, 2016 Report Posted October 14, 2016 There are several things you can do. The use of a cleat glued to the back as mentioned above would work. Adding a backer board will also thicken the piece. You can also mount your piece to a picture frame and use the hanger that comes with it. You can use a D ring type hanger glued with a product called E 6000. It is a thick adhisive that bonds anything to anything. I use it all the time without any failure. You can find it at any craft store. Lots of ways to do it! Quote
Scrolling Steve Posted October 14, 2016 Report Posted October 14, 2016 The E 6000 Dan mentioned is good stuff ! Quote
WayneMahler Posted October 14, 2016 Report Posted October 14, 2016 I use E-6000 for saw tooth and D-Ring hangers. Dries quick and gives a strong bond. Quote
savethebeer Posted October 14, 2016 Report Posted October 14, 2016 Folks. who makes E-6000. Never seen it here in Ireland Quote
JustLarry Posted October 15, 2016 Report Posted October 15, 2016 Folks. who makes E-6000. Never seen it here in Ireland I did a search for E 6000 glue in Ireland and came up with some locations shown. Some on e-bay, etc. You might give that a try. Larry Quote
crupiea Posted October 15, 2016 Report Posted October 15, 2016 I glue a 1 inch by 1/4 pice of 1/8" bb onto the back and then nail on one of those picture hanger things that have spikey things on each end to that piece of bb,. I have tried everything and this works the best. Quote
JTTHECLOCKMAN Posted October 15, 2016 Report Posted October 15, 2016 The best method is probably using wood glue and securing a small piece where the hook will go just to beef it up a tad. They sell small screws as small as you need them. I buy from here. www.smallboxhardware.com/prodview.lasso?searchfor=Fasteners&showtype=thumbs&searchitem=brass&shop=60&howMany=64.0&-session=Site_Preferences:47ACCE3418c2834480IKN3348705 Quote
Phantom Scroller Posted October 15, 2016 Report Posted October 15, 2016 I do the same as Larry superglue on screw and shorten them they won't come out. Roly Lucky2 1 Quote
lawson56 Posted October 15, 2016 Report Posted October 15, 2016 I,m gonna chk on the E-6000 Glue,I have been using a backer board and frame then snipping off the tip of the braid. Quote
Tommy Johnson Posted October 15, 2016 Report Posted October 15, 2016 Sloan's woodworking carries a good selection of small and short brass screws. Check them out also! Quote
Rolf Posted October 15, 2016 Report Posted October 15, 2016 I use 1/4 inch screws and the serrated hangers. Quote
Lucky2 Posted October 16, 2016 Report Posted October 16, 2016 I do the same as Larry and Roly, I've never had one fail doing it that way. Len Phantom Scroller 1 Quote
amazingkevin Posted October 16, 2016 Report Posted October 16, 2016 (edited) Folks. who makes E-6000. Never seen it here in Ireland 3-4 dollars craft stores ,big box stores,harewarestores Edited October 16, 2016 by amazingkevin Quote
amazingkevin Posted October 16, 2016 Report Posted October 16, 2016 i need some tips or ideas for hanging some of my projects. Since most of my projects that i want to hang is made from 1/4 inch baltic birch plywood i'm having a hard time finding screws short enough that they won't protrude to the other side when mounting hanging hardware. I'm leery of adhesive to stick the hardware to the wood for fear of it giving up and all that i worked for crashing to the ground. any suggestions will be appreciated. thanks, ray I never heard of it untill yesterday.I was asked to pick some up for a customer,she swears by it Quote
Phantom Scroller Posted October 16, 2016 Report Posted October 16, 2016 (edited) I never heard of it untill yesterday.I was asked to pick some up for a customer,she swears by it Well Kevin keep it away from her if she keeps swearing haa haa. Your've been quite lately Kev you ok mate. Roly Edited October 16, 2016 by Phantom Scroller Quote
