Ornaments For Charity eBook - Designers Wanted! ​​​​​​​🙏 ×
ouija board
breadstick
Finished this a few weeks ago. Put it together on the fly, so I didn't really have a pattern.  Backer is whiteboard and letters and symbols are stained poplar.  People at the festival seemed to really like it.
I was on a very short time frame, so I would have changed lots if I had the chance.
I was going to do the resin initially, but I never used it before and didn't have enough time to practice.  I definitely want to do it later. It'll be much easier to get everything straight.  What type of resin do you use?  I've read that some can scratch really easily and I don't want to make something that will look bad in a month.
If anyone wants to do it like this, don't use a table saw to cut the plastic.  First, it throws bits all over you and hurts.  Second, the edges are jagged.  I should have gotten a cutter from the hardware store and done it right, but time was not on my side.
I use easycast, mixed with a little acrylic paint to tint it to whatever color I want, I spray the whole board with a sealer and put felt pads on the planchettes to avoid scratching. The resin is a lot of work, although it's more forgiving than you might expect; mistakes can be sanded and redone. Your way is much easier.
