I would just LOVE to hear from Experienced woodworkers on this subject.
Bet many others would also.......
Example:  Plaque has been Stained....  Also 3 coats of MINWAX Clear Gloss Poly.
                 Want to GLUE words that have ALSO been stained and Varnished
                 to the surface of the Plaque.  Would there be ANY SPECIAL glue to use?
I know....I could experiment....but just THOUGHT this is a subject I haven't seen here.
Thanks for Any Input ..........................Danny  :+}
This is something like the question being asked about the lacquer painted backboard going on now too. There are some that will tell you E6000 will work. It is sort of an epoxy. Some will tell you a Med or thick CA glue may work( either one may work) but my opinion is use a 2 part epoxy. Titebond will not work either II or III That glue is meant to glue wood to wood. Whenever you have a gloss surface between you will run into problems and my choice would be epoxy. My choice of epoxy for any glue ups I do is Systems III T88
I too would have added the letters before top coating with the poly and then you could have used the Titebond products. Good luck
Edited by JTTHECLOCKMAN
Danny, try using gel-type CA glue, it will work as well as anything else would. The nice thing about using the gel-type, is that you can place as little or much as you want on exact spots. I use a lot of this type of CA glue, I like that you can be very precise where you place the glue.
Len
I have used super glue gel on a varnished surface and about 6 months down the track, pieces were starting to fall off.
It was the Lords prayer.........and I was pissed..................
Merlin
To make sure things stay put i'll use pins to go into both pieces an glue or i'll drill small 1/32" deep holes under the piece to be glued and the piece it's self so i'm glueing to raw pieces of wood together.
Dan (dgman) ....Actually I haven't fully applied the Poly to the letter lines.  Have given the back 3/8" BB a couple Sprays of Poly.
                          I have experimented with this and waiting for the Results.  Tomorrow....  AND I 100% BELIEVE IN AILEEN TACKY GLUE.
Kevin..............That is a Great Tip.  I shall be giving this method some thought.  Thanks.
Merlin.............I FEEL FOR YOU.  This is WHAT I AM WORKING ON.    "The Lords Prayer"  Sure Hate to present it to my Church
                       which I plan doing and say it gets hung and admired and months later some lines start falling off.  Sad.  Blush!  Would
                       make me feel real bad....             NOT GOING TO HAPPEN..............Thanks Everyone....................Danny  :+}|
