Hi there
I was thinking about using some led lightning in some of my projects, the thing is I dont know much about them. My question is has anyone ever used led lights if so how did they get on and what do I need to watch for.
Thanks
Martin
Martin, I have used LED lights on 3 lamp projects. Each had special requirements. All of the lamps had enclosed shades or enclosures so  no heat generation was very important. They were also candelabra style lamps because of size limitations. Because of the size of the "harps" for the shade, they had to be small. I had tried a round bulb first, but since 1/2 the bulb was encased in plastic, I didn't get the proper lighting effect. Your projects will determine what size and type of bulb you need. There is a large variety of bases, shapes and even warmth of light. Will the light illuminate through your scroll saw work and do you want it to be clear or opaque? You may need a colored or opaque Lexan or plastic to get the effect you're looking for.
Lots of choices with LED lights.
Martin
Can you give a better description of what your looking to do please. I have used LED lights in some of my projects for different effects. Some were plug in and some were battery operated. Just want to be sure of your goals and possibly I can  help. Thanks.
Hi there I was thinking of doing some projects where the light would pass through or wrap around the edges. I was planning in using led strip going around the outside, but I don't know what the effect would look like.
Martin, if your looking to make something like Wayne has posted, then you want battery operated led lights. I use Danson Decor brand for my projects, they operate off of three double AA batteries. They can be set to operate off of the timer, or, they can be set to stay on. I buy my lights at a dollar store, and I buy the twenty light sets. But, you can buy sets with fewer lights if needed. Personally, I don't think rope lighting will work, I don't know if it's the proper type of lighting. I think that the rope type of led lighting is to bright, I don't know if you would get the shadows to work the way they should to make the project to look right. The light sets that I use don't use a lot of power, the batteries usually last for 5-6 days before needing to be recharged. That's with the lights being turned on for about 6 hrs daily, and I use rechargeable batteries.
Len
wow
