Tape or No Tape
81 members have voted
  1. 1. On the topic of Taping:
    • No Tape--Pattern glued to wood, Cut
    • Painters' Tape, Glue Pattern and Cut
    • Painters' Tape, Glue Pattern, Packing Tape, Cut
    • Trace onto wood and then cut
Trackman started an interesting question on another thread, so I am trying to design a couple of fun polls.
These should be enlightening over the course of time.  The purpose is not so much to start a discourse of who is right, just a way to judge attitudes.
Right now I print, glue, painters tape and cut. Trying to get down what this guy is doing in this video. So far not getting as good results as he shows. (the pattern transfer part, from around 5.30 to around 13:00)--If anyone else has done this, would like to hear how yours turned out.
https://youtu.be/YbrOlc9-1Lk
Edited by 125 CSL
I read a book on marquetry written by Ken Horner.  He recommended a product known as application tape available through the Sign Warehouse in Texas.  I use the Enduramask line they offer.  It adheres well to the wood.  I then print my pattern on label sheets and adhere them to the Enduramask.  I have also used spray adhesive to adhere the pattern to the app tape.
When done, the Enduramask peels cleanly from the wood.
Edited by Blaughn
... Ken Horner.  He recommended a product known as application tape ...  ...  It adheres well to the wood.  I then print my pattern on label sheets and adhere them to the Enduramask.  I have also used spray adhesive to adhere the pattern to the app tape.
When done, the Enduramask peals cleanly from the wood.
GLAD Press'N Seal from the grocery store ....  post-5492-0-36136900-1478176350.jpg
peals cleanly from the wood and is clear so you can see the wood.
Depends on the project. Blue painters tape then glue for anything that may sit around and not get cut within a week or two (I'm terrible about starting this and not finishing til a month later).
But if I know I'll get it cut in the next day or so sometimes I use that Scroll Saw Tape from Scroller Magazine. I really like it but it can be a little pricey and it will come on stuck if it just sits around too long (couple weeks or more).
I've gotten away from using tape as much as I used to  I hate picking the tiny bits of painters tape left behind on detailed fretwork and I don't like packing tape on top, because of glare and the fact that it prevents mineral spirits from soaking in when trying to remove the pattern.  Applying painters tape, pattern, then packing tape seems like too much effort for little benefit, for me, anyway.  I typically use hot glue to keep my stacks together, instead of tape, so often I don't use any tape at all.
If I'm cutting fine detail in thicker, harder stock that is prone to burning, like cherry, I may use tape to help keep the blade cool.
