TripleJScroller Posted November 3, 2016 Report Share Posted November 3, 2016 For a long time I used the blue painter's tape and glue method, but I kept having trouble getting all the tape off without it taking bits of wood with it. So no I mostly just glue the pattern directly to the wood and use mineral spirits to remove it. That has worked fairly well for me though sometimes I put a bit too much glue on and have to scrub the wood a bit to get all the sticky residue off. Quote Link to comment Share on other sites More sharing options...
loftyhermes Posted November 3, 2016 Report Share Posted November 3, 2016 Repositionable spray glue onto back of pattern then glue to wood, packing tape only on thick wood 3/4" or thicker after holes are drilled. happy scrolling Steve Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted November 4, 2016 Report Share Posted November 4, 2016 mostly just spray glue an paste on the pattern Quote Link to comment Share on other sites More sharing options...
NC Scroller Posted November 4, 2016 Report Share Posted November 4, 2016 When tape is required, not all projects call for taping, I apply the pattern directly to the wood using 3M Super 77 and then put clear packing tape on top of the pattern. Quote Link to comment Share on other sites More sharing options...
banderson Posted November 4, 2016 Report Share Posted November 4, 2016 I only put packing tape over the intricate designs. California got rid of the spray adhesive that I liked. The stuff that they have now seems to not perform as well. Quote Link to comment Share on other sites More sharing options...
buck_lake Posted December 5, 2016 Report Share Posted December 5, 2016 Blue painters tape and use glue stick to fasten paper pattern Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted December 6, 2016 Report Share Posted December 6, 2016 I don't use tape,I never seen the need to, I've never had a problem removing the pattern remnants. I've been tempted to try using tape, but, that's only because of what I've read about other scrollers using it. Len Quote Link to comment Share on other sites More sharing options...
Sam777 Posted December 10, 2016 Report Share Posted December 10, 2016 I use what sign makers call Transfer Tape. I apply that directly to the wood, I print all my printing on full sheets of Avery white labels, I apply that to the wood after I had stuck the Transfer Tape to. Never had an issue with removing paper after the project is done. (keep in mind I don't scroll saw as much as any of you guys/gals) Sam Quote Link to comment Share on other sites More sharing options...
