jblock9907 Posted November 8, 2016 Report Posted November 8, 2016 After trying to attach to my original post, I give up, so I had to start a new one. One of the problems that I ran into is when I started cutting some of the smaller intricate cuts, the pattern would separate from the wood. I use Elmers repositional and Loc Tight repositional spray glues. Lucky2, hotshot, Smudger and 4 others 7 Quote
Scrolling Steve Posted November 8, 2016 Report Posted November 8, 2016 Very nice work !.....Well cut ! Quote
milehiscroll Posted November 8, 2016 Report Posted November 8, 2016 I LOVE IT.!!!!!!!!! HIT THE NAIL ON THE HEAD WITH THIS ONE.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks for sharing Quote
newfie Posted November 8, 2016 Report Posted November 8, 2016 Beautiful piece thanks for sharing Quote
DWSUDEKUM Posted November 8, 2016 Report Posted November 8, 2016 Very nicely done. Thanks for sharing this with us. DW Quote
meflick Posted November 9, 2016 Report Posted November 9, 2016 (edited) I am too new to offer too much in way of how to handle pattern lifting off. Others may have suggestions for you. I assume trying something else might be in order. I have had good luck using a Xyron machine with repositionable adhesive cartridges. If you have someone in the family who does paper crafting or scrap booking you may have one in the house already. If not, they can be bought at local stores who sell those types of products usually (and can often use a coupon on) or can be bought via Amazon. Love this pattern, its message and its beauty. You did an excellent job with it and I don't see any real flaw with it. Thanks for sharing your photo. Edited November 9, 2016 by meflick Quote
dgman Posted November 9, 2016 Report Posted November 9, 2016 Great looking plaque and nicely cut! I would rather struggle with removing the pattern after cutting, than struggle with the pattern coming off while cutting. I use 3M 77 spray adhisive. A light mist is all you need. Spray it on the back of the pattern, let it tack up for about 30 seconds or so. Apply it to the wood and start cutting. To remove the pattern I either spritz on some mineral spirits, let it sit fot about a minute and the pattern will just fall off, or I use a heat gun on the pattern. This will soften the adhisive and allow you to lift the pattern off. Quote
Lucky2 Posted November 9, 2016 Report Posted November 9, 2016 The cutting is outstanding, if the pattern is lifting off of the wood, then your not using enough glue. The glue you're using works fine, I use the same kind and have never had an issue with it. Len Quote
heppnerguy Posted November 9, 2016 Report Posted November 9, 2016 After trying to attach to my original post, I give up, so I had to start a new one. One of the problems that I ran into is when I started cutting some of the smaller intricate cuts, the pattern would separate from the wood. I use Elmers repositional and Loc Tight repositional spray glues. I have another suggestion about the pattern coming loose from the wood while you are cutting. I believe that you are probably using a good enough glue. I also believe you are using enough glue, as it takes very little to set up Ok. so my suggestion is......even if the wood you are putting the pattern is a sanded board, re-sand it with an electric sander,( if you have one), then wipe it clean of sanding dust followed by checking the cleanliness with the palm of your hand. If no dust is then present, place the sprayed pattern on the wood. rub your hand over the pattern you just placed on the wood to be sure it is flat on the wood with no air holes between the pattern and the wood. that should do it. I discovered this method after I too experienced your problem and I have not experienced again, since I have started do the above. I hope this might help you Dick heppnerguy amazingkevin 1 Quote
wombatie Posted November 9, 2016 Report Posted November 9, 2016 You certainly nailed that one. Well done. Marg Quote
lawson56 Posted November 9, 2016 Report Posted November 9, 2016 I Salute you.A Beautiful cutting. Quote
amazingkevin Posted November 9, 2016 Report Posted November 9, 2016 After trying to attach to my original post, I give up, so I had to start a new one. One of the problems that I ran into is when I started cutting some of the smaller intricate cuts, the pattern would separate from the wood. I use Elmers repositional and Loc Tight repositional spray glues. Her's one that the VA would salute hanging on their wall.Professionally one sir.Excellent cutting skills. Quote
GPscroller Posted November 11, 2016 Report Posted November 11, 2016 Beautiful piece! Thanks for the pic. Jeff Quote
