Sam777 Posted November 15, 2016 Report Posted November 15, 2016 Hi group I have cut a few pieces in Alder wood. Actually I used this wood to cut Travis's patter of wine glasses holder. This 3/4 wood is so tough to cut I would rather cut 3/4 Oak instead. I can through 2-3 blades in each piece. The fine grain seems to dull the blades quicker than oak. Do you experience the same issue. The finished Alder pieces are nice looking but I don't think it is worth the effort. Your comments please. Thank you Sam amazingkevin 1 Quote
amazingkevin Posted November 15, 2016 Report Posted November 15, 2016 Lucky you get to try the good stuff. Quote
Lucky2 Posted November 15, 2016 Report Posted November 15, 2016 I've only worked with alder wood a couple of times, I didn't find it hard to work with. Len Quote
dgman Posted November 15, 2016 Report Posted November 15, 2016 (edited) I work with a lot of Alder and find it easy to work with. In fact I find it softer than poplar. The only problem I have with Alder is, because it is soft, the cut edges need a lot of sanding. You didn't say what blade you used. I would use an FD Ultra Reverse #5 or #7 for 3/4" Alder. Edited November 15, 2016 by dgman hawkeye10 and Scrolling Steve 2 Quote
hawkeye10 Posted November 15, 2016 Report Posted November 15, 2016 Are you sure it's Alder you are cutting? I haven't cut Alder on the scroll saw but I have on the table saw and it is pretty soft and easy to work with. PS - I wonder if there is more than one kind of Alder? Quote
NC Scroller Posted November 15, 2016 Report Posted November 15, 2016 I use Alder all the time to cut compound projects. Never had any issues. I suspect you have some other species of wood. Can you post some pics? Quote
Rockytime Posted November 15, 2016 Report Posted November 15, 2016 I'll have to try Alder. I see it is available at my local Lowes. They seem to have a better selection than my local Home Depot. Perhaps each store varies. Quote
Sam777 Posted November 16, 2016 Author Report Posted November 16, 2016 To answer all: I started with #7 FDUR but half way in the piece I had to change to #5 and then again to #3. The #3 cut that 3/4 wood the best. I am trying to attach pictures but I haven't been able to figure out how to that. I feel stupid now :( May be like Scott is saying, may be this wood is not alder. It feels very soft yet is very dense. If someone can tell me how to post a picture, I will show you some. Thank you all Quote
Tommy Johnson Posted November 16, 2016 Report Posted November 16, 2016 Don't forget to use packing tape on your pieces. You will notice the difference! I have used Alder some and never had a problem cutting it. Have even Chip carved some. Quote
Bill WIlson Posted November 16, 2016 Report Posted November 16, 2016 Starting with a #7 but getting best results from a #3 seems odd. I would think that it would be the other way around. Typically one would expect the larger, more aggressive #7 to cut thick, dense wood more easily than a #3. I've never cut any alder, but it has a Janka scale rating of 590, which is just a little harder than poplar and much softer than cherry. I wonder if somehow you have some bad blades? Quote
NC Scroller Posted November 16, 2016 Report Posted November 16, 2016 At the bottom right of your screen you should see a button More Reply Options. Click on it. It should then pop up another screen to input your comments. Just below and to the left of the text input box you will see a paper clip and a button to Choose Files. Click that button and it should allow you to select pictures to upload. Quote
Sam777 Posted November 17, 2016 Author Report Posted November 17, 2016 Thank you Scott, Here are my pictures. I hope they show the wood species. Thank you all Quote
dottyblues Posted November 21, 2016 Report Posted November 21, 2016 I use Alder a lot and packing tape on both sides help. If I'm cutting 3/4 I use a #5 or #7 Olson Skip Reverse or #9RG Olson PGT blade. Quote
SCROLLSAW703 Posted November 21, 2016 Report Posted November 21, 2016 that looks more like cherry than alder. Quote
heppnerguy Posted November 21, 2016 Report Posted November 21, 2016 I also use a lot of Alder and it is one of my favorite woods. I do not find it to need much sanding as it seems to come out really nice for me. I don't mind using several blades when necessary as a sharp blade equals a nice finished piece. I sometimes use a small blade like O/2 and still find it cuts nicely. I am amazed by your problems Dick heppnerguy Quote
SCROLLSAW703 Posted November 22, 2016 Report Posted November 22, 2016 when cutting soft wood, the smaller blade the better. Not only because there is no need to use to a bigger blade, but, for less blade marks & less blades. Slow speeds are necessary, as well. In soft wood, the faster it's cut, the more it will burn, therefore breaking blades. Quote
Rockytime Posted November 22, 2016 Report Posted November 22, 2016 I will say this: mighty smooth cutting. Quote
kywoodmaster Posted November 22, 2016 Report Posted November 22, 2016 that looks more like cherry than alder. I was wondering if it might be cherry sap wood. That would explain the hard cutting. SCROLLSAW703 1 Quote
Sam777 Posted November 22, 2016 Author Report Posted November 22, 2016 I don't know what to say. I like the look of Alder. For the folks who suggested using clear tape to lube the blade, these were cut with clear tape on top only. I appreciate every bodies responses and suggestions. I will keep watching out when using this wood and I will keep posting about my progress when I use Alder. Thank again Sam Quote
SCROLLSAW703 Posted November 23, 2016 Report Posted November 23, 2016 that's kinda what i think kywood. As a rule, cherry isn't hard to cut, it burns easy if you try to run to high of a blade speed, or use an extremely fine blade. I use all rough sawn lumber in my projects, so i can plane it to whatever thickness i need. I try to use a # 3 or # 4, sometimes a # 5, it just depends on the detail. A lot of my projects start out at a 1/2". I do use a # 1 if the detail calls for it. I make dream catchers & crosses, & cut my own feathers for the dream catchers. They are right at 3/16". I have a couple crosses that are loaded with detail. I'll use a # 1, or sometimes a # 02. In cherry. You have to find a thickness you like to work with for starters. Then find a pattern you like to make. Then keep practicing with it until you feel comfortable with it. I tell my students the best thickness to learn blades, feel of the saw, feed rate, & turns is 3/8" - 1/2" thick. It doesn't tear out or crumble like the thin stuff does, & with less frustration. Yes, you'll still have blade size, speed, & feed rate to learn, but you'll learn that a lot faster in a thickness of wood you're comfortable with. You can look at my work on facebook at Sawdust Haven. Keep practicing, & keep reading & learning. Most of all, ask questions when you need to. God bless & enjoy the evening. Quote
amazingkevin Posted November 23, 2016 Report Posted November 23, 2016 (edited) Hi group I have cut a few pieces in Alder wood. Actually I used this wood to cut Travis's patter of wine glasses holder. This 3/4 wood is so tough to cut I would rather cut 3/4 Oak instead. I can through 2-3 blades in each piece. The fine grain seems to dull the blades quicker than oak. Do you experience the same issue. The finished Alder pieces are nice looking but I don't think it is worth the effort. Your comments please. Thank you Sam here ya go! Edited November 23, 2016 by amazingkevin Quote
stu Posted November 27, 2016 Report Posted November 27, 2016 Just finished making 30 mini bird house ornaments 1 1/2 square alder for grandsons class using fdur #3 and #5 no problems easy cutting biggest problem is drying if no air movement goes moldy stu Quote
