I have purchased my first puzzle blades from The Wooden Teddy Bear.
Tried to cut this puzzle (3/4" cherry) today, but the blade just kept drifting to the right something ferociously.  I could not control it at all, even though I increased the tension and made sure they were tight in the holders.
I finally stopped and started over with a #5 Modified Geometry by Pegas.
I agree with Katie and Dan, 3/4" stock is just to thick for a puzzle blade. I've used them in the past, and about the thickest I could cut was about 1/2" at best. And the 1/2" stock I was cutting was softwood, it cuts a lot easier then hardwood does.
Len
Trial and error.I'm having issues taking things apart .The blade is parallel to the table but may be the side of the blade is off?
I use #3 blades when cutting 3/4" poplar.  Just fine enough to keep the puzzle pieces from being too loose.
Iggy, there's a big difference between a #3 blade, compared to a #3/0 blade. The #3 blade is meant to cut wood with,a #3/0 blade is considered a jewelers blade.
Len
Len
I'm fully aware of that Len.  I was simply letting him know what I use to cut 3/4 inch wood puzzles so he could give it a try since I cut 30-35 of them a week and he said the #5 blades were too loose.
Edited by Iguanadon
Iggy, I'm sorry, I don't know where my head was at when I replied the way I did. I should have been agreeing with you, I use the #3 blade for the same purposes.
Len
