shoptime Posted November 26, 2016 Report Posted November 26, 2016 has anyone ever replaced the bellows on a Dremel 1680? Was it pretty straight forward? Thanks, Sean lawson56 1 Quote
amazingkevin Posted November 26, 2016 Report Posted November 26, 2016 has anyone ever replaced the bellows on a Dremel 1680? Was it pretty straight forward? Thanks, Sean you know i've taken them apart many times and i don't recall ever seeing one,Huum? Quote
Lucky2 Posted November 27, 2016 Report Posted November 27, 2016 Sean, rather than replace the bellows, why don't you just get a small aquarium pump? It would do the job real well, and you wouldn't have to take your saw apart. Len Phantom Scroller 1 Quote
lawson56 Posted November 27, 2016 Report Posted November 27, 2016 I have replaced them on a Porter Cable,Rather tight, Quote
crupiea Posted November 28, 2016 Report Posted November 28, 2016 Sean, rather than replace the bellows, why don't you just get a small aquarium pump? It would do the job real well, and you wouldn't have to take your saw apart. Len I use this and some aquarium tubing. To make it pointy in the end i stuffed a piece on ink pen in the end. taped it along side of the current tube, works great. I saw on the slowest speed so the bellows dont blow enough off at that slow speed. pump works great. Quote
shoptime Posted November 30, 2016 Author Report Posted November 30, 2016 I think I'll go the aquarium pump way. i would at least have a steady stream of air movement. Thanks, Sean Quote
