2024 Custom Ornament Business Kit - Now Available - SALE 50% Off Through Dec. 2nd ×
Blades for 3D cutting?
hawkeye10
I have done 100's of compound pieces.  Some as thick as 2".  Hands down I prefer the Flying Dutchman Polar Blades in either a #5 or #7.  FYI pine while a soft wood is not all that easy to compound cut because the blade will tend to follow the grain.  Also DO NOT compound cut any piece with a knot in it.  The knot will break and fall out and ruin the piece 99 times out of a 100.  Trust me.
Scott advice taken, thanks. What wood do you like to cut compound pieces the best?
Cedar will be the easiest to cut. I made dozens of bird houses and I used pieces of scrap that I glue together to get the thickness, so I used jusy about every kind of wood. Oak, ash, walnut, cherry, yellow and purple heart(not recommended very hard wood) so the sky is the limit.  I agree on blades choice FDUR # 5 and 7.
I use a variety.  My two favorite woods are Poplar and Butternut.    Butternut is often called poor man's walnut.  I also use basswood and aspen on a regular basis.  I am lucky as I have a hardwood store a couple hours from me so I can purchase 5/4, 6/4, 8/4 and even thicker stock.   It is sold by the board foot but you would be amazed on how much you get per board foot. My last trip I got 8/4 basswood for $3.40 a board foot.
Another compound cutting trick is to enlarge or reduce patterns to fit the size wood I have available.  For example if the pattern calls for 1 1/2" wood and all you have is 1" wood copy it at 66%.  Have a 1" pattern and want to cut it on 1 1/4" stock copy it at 125%.  You get the picture.
