Frank Pellow Posted December 1, 2016 Report Posted December 1, 2016 (edited) (part 1 of 2) Last week, I designed a 'Wishing You a Cool Yule' plaque insert for our front door. A couple of days after designing this, I got to thinking that it might be possible to make a variation of the plaque insert that is small enough and light enough to serve as a seasonal greeting card. And, sure enough, I came up with a pattern and instructions to do just that. Both patterns can now be found in the pattern library here at Scroll Saw Village. I give credit to 'bobscroll for the snowman that I utilized in these patterns. Edited December 16, 2017 by Frank Pellow update for 2017 version of cards Phantom Scroller, wombatie and lawson56 3 Quote
Frank Pellow Posted December 1, 2016 Author Report Posted December 1, 2016 (edited) (part 2 of 2) The black part is intended to be removed leaving a ‘To’ tab at the top left and a ‘From’ tab at the bottom right.I reduced the size so that it can fit into a “standard†9 inch by 7 inch padded envelope that can be purchased relatively cheaply in bulk from most stationery stores.I cut the prototype out of 3mm thick Baltic birch plywood and “manufactured†a piece of 2mm thick clear pine with the same width and height to use as a backer board.. I could have used a second piece of plywood for the backer but I believe that would put to total weight of the card, the envelope, and other contents over 100 grams. Once one goes over 100 grams, the postage rates (at least in Canada) take a BIG jump. In the first photo attached below, I am weighing everything, including a couple of strips of sticky-back Velcro, should the recipient wish to display the card.The combined weight is 92 grams. I completed the prototype card and gave it to Margaret. Margaret was truly surprised and delighted with both the concept of making such a card and the card itself. Attached below are photos of the card and the card’s current location where it is stuck with Velcro on the window behind our kitchen sink:The foreground board was painted with dark blue metallic acrylic paint. Appropriate parts of the background board were painted with white, copper, orange, and green acrylic paint. The two boards were glued together using Lepage’s No More Clamp glue. I’m going to attempt to stack cut 6 of these. So far, my stack cutting on other projects has been so-so, therefore I’m keeping my fingers crossed. Edited December 2, 2016 by Frank Pellow Scrolling Steve and Phantom Scroller 2 Quote
DWSUDEKUM Posted December 1, 2016 Report Posted December 1, 2016 That is a great idea and cutting Frank. I really like this project. Thanks for sharing this with us. DW Quote
Scrolling Steve Posted December 1, 2016 Report Posted December 1, 2016 That came together nicely !......That's using the old head! Quote
Phantom Scroller Posted December 1, 2016 Report Posted December 1, 2016 Very good idea Frank thanks for my copy. :cool: Roly Quote
amazingkevin Posted December 2, 2016 Report Posted December 2, 2016 (part 1 of 2) Last week, I designed a 'Wishing Yo a Cool Yule' plaque insert for our front door. A couple of days after designing this, I got to thinking that it might be possible to make a variation of the plaque insert that is small enough and light enough to serve as a seasonal greeting card. And, sure enough, I came up with a pattern and instructions to do just that. Both patterns can now be found in the pattern library here at Scroll Saw Village. I give credit to 'bobscroll for the snowman that I utilized in these patterns. good looker ,Stand out great ! Quote
Dave Monk Posted December 2, 2016 Report Posted December 2, 2016 Great idea! Thanks for sharing. dave Quote
Lucky2 Posted December 2, 2016 Report Posted December 2, 2016 Thanks Frank, great idea and pattern. Len Quote
Ron Johnson Posted December 2, 2016 Report Posted December 2, 2016 Someone has been doing serious thinking. Well done Frank. Quote
Frank Pellow Posted December 2, 2016 Author Report Posted December 2, 2016 My stack cutting remains so-so as can be seen in the two attached images. I stack cut six 3mm thick pieces of Baltic Birch plywood, with mixed results. The snowman, cut with a Flying Dutchman Ultra Reverse UR3 blades worked out VERY well. The large letters cut with a flying Dutchman New Spiral NS3 blade worked out well. The small letters first cut with a Flying Dutchman NS1 blade were a failure. I switched to Flying Dutchman NS2/0 blades after screwing up a few times and the letters cut that way are OK. I'm going to keep the top 5 pieces and hope that, once painted and mounted, the recipients will not notice the flaws. The bottom piece (in the bottom right of the photo) will be thrown out. The spiral 2/0 blades really have to work hard with this thickness of plywood and the wood has to be pushed hard against the blade, something that I am not used to doing. I also learned that, when cutting the small letters, the interior cuts should be made first, otherwise the material one is cutting is very week and apt to break. Phantom Scroller 1 Quote
meflick Posted December 2, 2016 Report Posted December 2, 2016 Thanks for sharing Frank. Both your idea, the pattern and the updated information on your stack cutting attempts and blades used. Good to read and learn from other's. Quote
GPscroller Posted December 3, 2016 Report Posted December 3, 2016 Neat idea Frank. Thanks for the pics. Jeff Quote
wombatie Posted December 4, 2016 Report Posted December 4, 2016 What a terrific idea Frank. Looks great too. Well done. Marg Quote
Frank Pellow Posted December 4, 2016 Author Report Posted December 4, 2016 (edited) Into Production: Yesterday, I really got into “production†mode on these cards. The first part of this is, obviously, the stack cutting of the foreground pieces. I also needed to speed up the painting of the backer-boards. To this end, I created a couple of painting templates, one for the white areas and the other for the rest of the colours. I'm attaching a couple of photos of painting underway on backer-boards using templates. Edited December 4, 2016 by Frank Pellow Quote
Frank Pellow Posted December 6, 2016 Author Report Posted December 6, 2016 Painting, painting, painting ... It turns out that I am spending more time painting and assembling these things than I am scrolling. Oh well, that's how it goes. Phantom Scroller 1 Quote
Frank Pellow Posted December 10, 2016 Author Report Posted December 10, 2016 (edited) Last card mailed: The attached photo shows the last of 34 cards being inserted into an envelope. I would not have started this project if I had known how time consuming it would be. The amount of scrolling involved was just about what I expected. But, I estimate that the scrolling time was only 25% of the total time. On the other hand, I have gotten enthusiastic feedback from folks who have already received their cards. Edited December 10, 2016 by Frank Pellow Quote
Frank Pellow Posted December 16, 2017 Author Report Posted December 16, 2017 (edited) It appears that I've really started some sort of tradition. A number of folks who received one of my cards last year asked if I was going to create one again this year. Hence, I did: The pattern for this new card can be found in the thread: Edited December 21, 2017 by Frank Pellow Phantom Scroller and Scrappile 2 Quote
Phantom Scroller Posted December 17, 2017 Report Posted December 17, 2017 Loads of potential in this one Frank changing patterns etc for Easter as well . Roly Quote
