hawkeye10 Posted December 8, 2016 Report Share Posted December 8, 2016 I can't remember any one talking about doing maintenance on their EX scroll saw's. I am talking about inside where the bearings are. I do keep the blade clamps and the white nylon tensioner lubed. Quote Link to comment Share on other sites More sharing options...
Scrolling Steve Posted December 8, 2016 Report Share Posted December 8, 2016 Don, my EX 21 is almost 3 years old and the only maintenance i have done is exactly what you are doing....The bearings are sealed. tomsteve and Lucky2 2 Quote Link to comment Share on other sites More sharing options...
bandaideman Posted December 8, 2016 Report Share Posted December 8, 2016 What is the lube for the Nylon tensioner about. Doesn't that cause it to release easy when scrolling? Quote Link to comment Share on other sites More sharing options...
hawkeye10 Posted December 8, 2016 Author Report Share Posted December 8, 2016 What is the lube for the Nylon tensioner about. Doesn't that cause it to release easy when scrolling? Dan I was talking about the white lever you flip to tighten the blade after installing it. I lube the bearing surface so it won't wear as quick. tomsteve and Scrolling Steve 2 Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted December 9, 2016 Report Share Posted December 9, 2016 Don, I've never done that type of service to my saw, and I don't plan to until the saw sounds different in any way. There's and old saying out there, something about "if it ain't broke, don't fix it". It'a a wise saying, It's just to sad that most people don't pay much attention to it. There should be no issues with your bearing, they are sealed. Even if you do add grease, it won't be getting to the bearings unless you break the seal. If you do that, then you deserve whatever happens. If you want to service and grease your saw, then grease only the parts that move. The pivot points and rocker arms, other then that there's nothing else to grease. Len amazingkevin 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted December 9, 2016 Report Share Posted December 9, 2016 Don, I've never done that type of service to my saw, and I don't plan to until the saw sounds different in any way. There's and old saying out there, something about "if it ain't broke, don't fix it". It'a a wise saying, It's just to sad that most people don't pay much attention to it. There should be no issues with your bearing, they are sealed. Even if you do add grease, it won't be getting to the bearings unless you break the seal. If you do that, then you deserve whatever happens. If you want to service and grease your saw, then grease only the parts that move. The pivot points and rocker arms, other then that there's nothing else to grease. Len Len i wish dw788's had all sealed bearings .i could have saved a lot of money not buying so many just to keep scrolling!i wonder if ex and dewalt bearings are interchangeable.they are basically the same machine inside???? Quote Link to comment Share on other sites More sharing options...
hawkeye10 Posted December 9, 2016 Author Report Share Posted December 9, 2016 Len i wish dw788's had all sealed bearings .i could have saved a lot of money not buying so many just to keep scrolling!i wonder if ex and dewalt bearings are interchangeable.they are basically the same machine inside???? Kevin there is a video on UT showing how to do maintenance on the 788 but you already know that. What you may not know is they tell where you can buy better and cheaper bearings for your saw. Now ain't that great??? tomsteve 1 Quote Link to comment Share on other sites More sharing options...
tomsteve Posted December 9, 2016 Report Share Posted December 9, 2016 (edited) I found bearings can be found less expensive at places other than the manufacturer of the tool/equipment or ereplacementparts and places like that. I usually go to places like that to get the bearing # then start cross referencing and it might be possible to put sealed bearings in the 788. as far as maintenance on my EX, I blow it off and once a year I pull the rocker arms apart,clean them thoroughly, and a light coat of grease. its not required, but I just do it. sealed bearings rock!! the owners manual only shows to add a dab of grease to the trunions Edited December 9, 2016 by tomsteve Quote Link to comment Share on other sites More sharing options...
