Doing a fretwork clock with delicate cuts, and the Olsen Crown seems to be doing a good job. But be very aware that since it  cuts in both directions, if the blade is upside down in it's placement, the cut line will pull left rather than right which we are so used to. Screwed up one section because of this. Test the blade placement on a scrap before you do your on purpose cuts.
Blades are all made with different configurations. If your trying to eliminate the fuzzies on the back side of the cutting. A blade with alternating teeth may help. I use UR blades and a quick run with the ROS does the job quick and efficiently. Just my thoughts.
What is a "ROS" or what does it stand for?
No because it is a matter of what saw is being used. The travel of the blade is different on all saws. Put an auxilary table top and it changes things even more. All you need is a couple teeth to knock the fuzzies off. You are not cutting with those teeth. If you want to cut with both up and down stroke then use a combination blade.
ok great my friend now i can sleep tonight,lol
thank you Wayne,Guess i should read up on blades once in a while
i get to used to one blade for everything    , change is nice though thanks Mr Slasher
