Blaughn Posted December 11, 2016 Report Share Posted December 11, 2016 The material in this picture is 10" x 2" x 3/8" cherry cut with the Olson 2/0 blade. Two questions: 1. I re-sawed a piece of 4-quarter cherry to get the 3/8 material for the plaque. The board is a bit cupped and a bit bowed as internal pressures were relieved. I intend to glue the completed piece to 1/2" plywood as a backer board when done. I am hoping expect that will flatten the piece. Before I do all the scroll work, do you think 1/2 inch ply will flatten the cherry? 2. As I was cutting the sample piece shown above, I noticed the cut was requiring more pressure about half-way through the scrolling. Would you expect to have to change a Olson 2/0 blade half way through the above sample? Bruce amazingkevin, Lucky2 and LarryEA 3 Quote Link to comment Share on other sites More sharing options...
Sparkey Posted December 11, 2016 Report Share Posted December 11, 2016 Looks great. I would expect to be able to cut a couple out with one blade. You could wear the blade out sooner if the saw is running fast and the blade is getting too hot or if you are pushing too hard. I cut out an October Cross with only two blades in 3/8" purple heart using FD new 3/0 spirals. I run medium speed and just let the saw do the cutting. amazingkevin 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted December 11, 2016 Report Share Posted December 11, 2016 Bruce, should look good when done. When you cut the pieces how did you sand them to get flat??? If the plywood is flat it has a good chance of holding the cherry flat. Make sure when you glue it to weight it down so that the cherry flattens out. Scrolling the letters out will also take some of the stress out of the board too. Seems a bit odd though that you use 3/8 for the finish piece and use such a heavy piece for the backer unless you are going for a certain look. Quote Link to comment Share on other sites More sharing options...
Blaughn Posted December 11, 2016 Author Report Share Posted December 11, 2016 Bruce, should look good when done. When you cut the pieces how did you sand them to get flat??? If the plywood is flat it has a good chance of holding the cherry flat. Make sure when you glue it to weight it down so that the cherry flattens out. Scrolling the letters out will also take some of the stress out of the board too. Seems a bit odd though that you use 3/8 for the finish piece and use such a heavy piece for the backer unless you are going for a certain look. I did no sanding after resawing. I simply ran it through the planer which does nothing to flatten, unfortunately. My choice of 1/2" ply is based upon the fear that 1/4" would be overpowered by the cherry. If the scrolling helps to flatten the board, I may choose 1/4 for the recessed backer. My other choice, though, would be to use the other piece of 3/8" cherry produced when I re-sawed the original board. I could glue it up after re-aligning the original grain then cut the decorative edge to finish the plaque. That would make the scrolling appear to be routed into a piece of solid cherry.......hmmm.... Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted December 11, 2016 Report Share Posted December 11, 2016 IMG_05851.JPG The material in this picture is 10" x 2" x 3/8" cherry cut with the Olson 2/0 blade. Two questions: 1. I re-sawed a piece of 4-quarter cherry to get the 3/8 material for the plaque. The board is a bit cupped and a bit bowed as internal pressures were relieved. I intend to glue the completed piece to 1/2" plywood as a backer board when done. I am hoping expect that will flatten the piece. Before I do all the scroll work, do you think 1/2 inch ply will flatten the cherry? 2. As I was cutting the sample piece shown above, I noticed the cut was requiring more pressure about half-way through the scrolling. Would you expect to have to change a Olson 2/0 blade half way through the above sample? Bruce now here a perfect word art i've never cut ,well done! Quote Link to comment Share on other sites More sharing options...
hawkeye10 Posted December 11, 2016 Report Share Posted December 11, 2016 IMG_05851.JPG The material in this picture is 10" x 2" x 3/8" cherry cut with the Olson 2/0 blade. Two questions: 1. I re-sawed a piece of 4-quarter cherry to get the 3/8 material for the plaque. The board is a bit cupped and a bit bowed as internal pressures were relieved. I intend to glue the completed piece to 1/2" plywood as a backer board when done. I am hoping expect that will flatten the piece. Before I do all the scroll work, do you think 1/2 inch ply will flatten the cherry? 2. As I was cutting the sample piece shown above, I noticed the cut was requiring more pressure about half-way through the scrolling. Would you expect to have to change a Olson 2/0 blade half way through the above sample? Bruce Bruce I have learned that scroll saw blades wear out fast "very fast". When I change holes scrolling I will rub my thumb on the part of the blade that is doing the cutting then rub the part that is not cutting and compare. If it feels just a little dull I change blades. You will be very surprised how fast they get dull. Quote Link to comment Share on other sites More sharing options...
Falcon Posted December 11, 2016 Report Share Posted December 11, 2016 I just bought Olson blades 2.0 for the first time. Not impressed at all my Flying Dutchman last a lot longer. Personally will not buy them anymore. (Just my experience) Quote Link to comment Share on other sites More sharing options...
Blaughn Posted December 12, 2016 Author Report Share Posted December 12, 2016 Bruce I have learned that scroll saw blades wear out fast "very fast". When I change holes scrolling I will rub my thumb on the part of the blade that is doing the cutting then rub the part that is not cutting and compare. If it feels just a little dull I change blades. You will be very surprised how fast they get dull. Given the cost per blade vs the cost of the wood and my time, I am inclined to agree with you. Thanks for your input. Quote Link to comment Share on other sites More sharing options...
Blaughn Posted December 12, 2016 Author Report Share Posted December 12, 2016 I just bought Olson blades 2.0 for the first time. Not impressed at all my Flying Dutchman last a lot longer. Personally will not buy them anymore. (Just my experience) I have Flying Dutchman SR from size 12 down to 2/0. I have been so impressed with them (primarily the #5), it was a no brainer to use the FD SR 2/0 when the project called for it. I found that blade to be extremely difficult to control. They seemed to lag behind in responding to the slight adjustments and then over respond to the next correction. I tried the Olson 2/0 and the problem went away. For my machine, the material I am working with currently and my touch, the Olson 2/0 have found a home but the FC SR #5 is still my go-to blade for most work. Offered not as a rebuttal nor an argument to your post - simply my impressions as a new scroller. Falcon 1 Quote Link to comment Share on other sites More sharing options...
