danny Posted December 16, 2016 Report Posted December 16, 2016 HAS ANYONE RIGGED UP THEIR OWN WAY TO SUCK THE SAWDUST VIA VACUUM TUBES FROM BOTTOM AND TOP? WOULD JUST LOVE TO READ HOW YOU RIGGED IT. THANKS..................Danny :+} Scrolling Steve 1 Quote
hawkeye10 Posted December 16, 2016 Report Posted December 16, 2016 Danny my EX16 came with dust collection but it was so loud an kept getting clogged up with small cutoff's I took it off. Look at the photo and you can see what I came up with. One fan blowing across the table and into the filter of the other does a pretty good job. I also wear a dust mask. Lucky2 1 Quote
jbrowning Posted December 16, 2016 Report Posted December 16, 2016 Hello Don, this might be a foolish question. But I am assuming the box fan is blowing away from the Excalibur? Thanks Jim Quote
tomsteve Posted December 16, 2016 Report Posted December 16, 2016 (edited) theres a video on youtube of a guy that did modifications to his excaliber and the dust collection was one of the mods. Edited December 16, 2016 by tomsteve Quote
hawkeye10 Posted December 16, 2016 Report Posted December 16, 2016 Hello Don, this might be a foolish question. But I am assuming the box fan is blowing away from the Excalibur? Thanks Jim Yes it's blowing away. The 20"x 20" filter catches the dust and I vacuum it off with the shop vac. Quote
danny Posted December 16, 2016 Author Report Posted December 16, 2016 Thanks for ALL the Posts. Don I have had that same set up for many, many years. It does a OK job with the square fan andFilter catching the majority of the sawdust. I still get a little sawdust that just doesn't get captured and consequently it floats ALL OVER THE PLACE. Anyway I do thank you for your input................................Danny :+} Quote
Sycamore67 Posted December 16, 2016 Report Posted December 16, 2016 I have a Hegner 18VS which I have adapted for dust collection both above and below the table. I used 3/4" PVC pipe and fittings and also some larger to attach to my HEPA Vac. Above the table I used 3/4" Loc Line for a vacuum pick up and also Loc Line for the blower part. Both are easy to move and position to pick up the fine dust. Below the table is a 3/4" PVC pipe to suck up the dust below the blade. The system is very effective and there is very little dust which escapes. With this setup, I do not need to wear a dust mask. Scrolling Steve and amazingkevin 2 Quote
Terry Jay Posted December 17, 2016 Report Posted December 17, 2016 Festool sells a ":Y" that fits the smaller hose (1-1/2"?) shop vacs. Quote
Sam777 Posted December 18, 2016 Report Posted December 18, 2016 Danny my EX16 came with dust collection but it was so loud an kept getting clogged up with small cutoff's I took it off. Look at the photo and you can see what I came up with. One fan blowing across the table and into the filter of the other does a pretty good job. I also wear a dust mask. I also use a MASK and have the SAME SETUP on my EX 16 except I have not upgraded to the addition of the small blower fan I depend on the little blower tube which leaves my saw table top with layer of dust as I am working. I will upgrade Sam Quote
jrpeteo Posted December 19, 2016 Report Posted December 19, 2016 I use a regular shop vac in another room operated by remote control. Had a lot of help on this from member "Multifaceted" (Carl Jacobs). I had severe COPD and had to remove as much sawdust as possible. How I made it. https://youtu.be/DnVFuMb4LqM Mounted on saw. With upgraded light. https://youtu.be/XCWK-yJ1U4A In use. https://youtu.be/5j7AcrcDiB0 poupster2 1 Quote
amazingkevin Posted December 19, 2016 Report Posted December 19, 2016 I use a regular shop vac in another room operated by remote control. Had a lot of help on this from member "Multifaceted" (Carl Jacobs). I had severe COPD and had to remove as much sawdust as possible. How I made it. https://youtu.be/DnVFuMb4LqM Mounted on saw. With upgraded light. https://youtu.be/XCWK-yJ1U4A In use. https://youtu.be/5j7AcrcDiB0 i miss carl on the forums Quote
danny Posted December 21, 2016 Author Report Posted December 21, 2016 Pete I simply Love the way your saw is Dust Free after Scrolling. I wish to eventually set up something like yours. Haven't decided how yet. Still investigating and asking questions. I VERY MUCH ENJOYED WATCHING YOUR VIDEOS WITH YOUR ....HOW TO.... Thanks for showing this Interest. Did teach me things.... Danny :+} jrpeteo 1 Quote
