hawkeye10 Posted December 18, 2016 Report Posted December 18, 2016 I am cutting a dog puzzle so do I need to change blades to cut the veining cuts? Does the veining cut need to be narrower or wider? I am using a FD UR #5 blade. This is my first puzzle. Quote
ike Posted December 18, 2016 Report Posted December 18, 2016 I use the same as cutting the pattern with. I have seen to use a #2 but I don't want to change blades when It's not necessary IKE. tomsteve and WayneMahler 2 Quote
Dan Posted December 18, 2016 Report Posted December 18, 2016 I agree with Ike. You can cut the veining whatever size you want. To me, thin veins in these puzzles don't show up that well. I also have been using a #5. If you prefer the thinner veins, just drill the proper size hole for the blade you want to use. Remember, these patterns are just a guide. WayneMahler and tomsteve 2 Quote
dgman Posted December 18, 2016 Report Posted December 18, 2016 I agree with Ike and Dan however I use an FD UR 3 blade for stand up puzzles. It make for a narrower kerf so the puzzles stays together better. tomsteve 1 Quote
amazingkevin Posted December 19, 2016 Report Posted December 19, 2016 I don't bother to change blades ,less work for me and nobody's the wiser! Quote
Lucky2 Posted December 19, 2016 Report Posted December 19, 2016 Don, for me, it all depends on how it's going to look. If it looks as if it will be an improvement, then I'll change the blade. If it looks like it won't make a difference, then I don't bother changing blades. Len Quote
hawkeye10 Posted December 19, 2016 Author Report Posted December 19, 2016 I don't bother to change blades ,less work for me and nobody's the wiser! Kevin we had a saying at work. "Don't work harder work smarter" Merry Christmas blights69 1 Quote
Iguanadon Posted December 21, 2016 Report Posted December 21, 2016 I use a #3 blade for everything. I'm too lazy to swap out blades. Quote
hawkeye10 Posted December 21, 2016 Author Report Posted December 21, 2016 I use a #3 blade for everything. I'm too lazy to swap out blades. We must be kin. Merry Christmas Quote
