Rolf Posted December 21, 2016 Report Posted December 21, 2016 (edited) Beautifully done.The Cherry was a great choice and the effort you put into the finish was well worth it. What did you use to rub out the final coat? Edited December 21, 2016 by Rolf Quote
Phantom Scroller Posted December 21, 2016 Report Posted December 21, 2016 Looks beautiful in that wood. Roly Quote
GPscroller Posted December 21, 2016 Report Posted December 21, 2016 Awesome piece! Am sure your daughter will be thrilled. Thanks for sharing. Jeff Quote
Dave Monk Posted December 22, 2016 Report Posted December 22, 2016 Beautiful job and gorgeous finish. dave Quote
Blaughn Posted December 22, 2016 Author Report Posted December 22, 2016 On 12/21/2016 at 3:24 PM, Rolf said: Beautifully done.The Cherry was a great choice and the effort you put into the finish was well worth it. What did you use to rub out the final coat?I I always wear vinyl glove when finishing. After a light wet sanded using wipe on poly and 600 grit wet or dry, I wiped off the excess lightly with a cloth and let it dry overnight. Then, the next morning, I applied a very light coat of wipe-on poly with a cloth which rubbed in with my vinyl glove covered fingers with long strokes with the grain. As I did, it began to take on the desired sheen so I set it aside to dry completely. When dry, I buffed it with a clean dry cloth. Quote
