I made my first puzzle out of pine when I picked it up I broke a piece off. That happening to a child might be a chocking hazard. I have read some use poplar which I can buy for $1.60 a board foot while the pine is $1.05 a foot. Price doesn't matter when we are talking safety. I am now cutting one out of "alder". I will let you know how it turns out. So what wood or woods do y'all use?
Merry Christmas
I don't cut the Woodimal puzzles, but t do cut a lot of standup puzzles. I always use hard woods like Cherry, Maple and Red Oak. Why? Because the harder, the less likely to break. Poplar and Alder are hardwoods but are softer than others, so I don't use them.
I use only hardwoods for my puzzles because of their durability. Cherry, maple, walnut, padauk, locust, etc. I avoid poplar like the plague for the reason you mentioned.
Edited by orangeman
For me, it all depends on what the puzzle will be used for. If it is just going to be used as a decoration, then fine, I will use pine, poplar, or any other kind of wood. If the puzzle is to be used by a small kid, then I use baltic birch. I use the BB because it's so durable, it hardly ever breaks, not even the tabs. No matter what type of wood you use, there's always a chance of it breaking especially where the wood is thin in areas. I always sand the BB before I glue the pattern on, and when I'm done cutting the puzzle out, I remove the pattern paper with after-wash. It's the same as paint thinner, and it removes every bit of glue residue. After all of the glue residue is removed, then I can use whatever I want for a finish.
Len
Although I haven't tried it, some folks use BB plywood. I could see using 1/2" but 3/4" may be a little tougher. I may try some this weekend.
Dan I have been thinking about using BB ply but as I have read here on the SSV forum these puzzles need to be 3/4" thick to stand up. I do have some 1/2" but no 3/4". Like you I think I will try some this weekend. I think BB ply would look okay.
The wood does need to be at least 3/4" in order to standup easily. I usually use 7/8". I would not use less than 3/4".
I make stand up puzzles but few are the Woodimal ones.  I use mostly soft maple, oak and walnut.  I have used some pine but only the clear pine (no knots) and only on puzzles with no fragile parts.  The only time I have used poplar is for a penguin puzzle because I stain it to get the colors I want.  To me the $0.50 or $1.00 more per puzzle it costs to use better woods is worth it.
