Merry Christmas,
Having trouble with the FD UR 3 blades. Blades squeal/chatter big time. It doesn't matter what type of wood, thickness or speed. I've tried blades from different packs and still I had the squealing. UR #5's work fine. My saw is EX21.
I am a huge fan of the Pegas modified geometry blades. But I really appreciate the service and speed that
I get from Mikes/Wooden Teddy Bear.
Looking for suggestions that any of you have.
Thanks
I agree with the other scrollers, it has to be not enough tension. I put as much tension as possible on all sizes with the exception of the 2/0 flat and spiral blades, on those I back off just a hair. Since you use the #5 ur you probable know about the crimp on one end being in the top blade clamp.
Erv
Thank you all for your help. Yep, I do know that the crimp has to be on top.
As for the tension, I think they are tensioned tight enough because I do listen for the "ping".
Hopefully not a bad batch.
Which leads to another question about tensioning, which maybe should be another thread. If I need to readjust the tension on my EX, I just rotate the knob in the back, right? But if I do that, then the arm isn't parallel to the table, which in turn, won't give me a "true" up and down motion of the blade.
I don't know about the EX  but if I remember correctly, most saws do not run an true parallel on the blade so that they clear the sawdust better which in turn helps the blades to cut faster and better. I could be wrong about what i remember,as that happens to me often as I get older but that is what I seem to recall
Dick
heppnerguy
Check blade travel.  On the EX, if you mess with the knob in the back, you can induce excessive blade travel.  You can never get all the travel out of the EX, but you can tune it to make it nominal.
Of course, if you are not seeing this with the other blades, the blade travel theory get's pretty weak.  Unless you are putting the blades in upside down, I can't think of another reason for the chatter.  You might try sending a blade or two to another frequent user of that blade on the forum, who could do a quick sanity check.
-------Randy
I use UR's pretty much exclusively and never had a problem like this. I would check all the alignments and make sure eerything is set right. Not sure what else to say here, but following this thread for future reference also.
I use the ex21 with the 3/0 blade most of the time. Never had that problem. I did have a bunch that would break as soon as I started uo the saw. They were defected. Mike sent me a new batch and they were fine. Could be some bad one's in there.
After reading everyone's comments, I have to believe I may have a bad batch, for the simple reason that the UR#5's don't chatter, nor do any other blades. The "ping" is there, so I have to believe the tension is correct. I'm thinking I'll give Mikes/Wooden Teddy Bear a call and see what they have to say.
Thanks again for everyone's input.
