All ashtrays should have cigarette or cigar burns.   :D
Dip them in .... liquid tin... but then you lose the wood look.
... wood you should not use to make an ashtray--- 'Fatwood' :D
... also, it's a rare piece of wood that wants to be an ashtray.  :sad:
Nothing that I know of. Sorry, I can't help.
Edited by LarryEA
Jerry, there's nothing I know of, that will stand up to the heat of the cigarette coal. It will melt and burn, and there's always the possibility of the ashtray catching fire from an unattended cigarette. The box/dish your showing is far to deep to be used as an ashtray, it should be no higher then 1 and 1/2 inch high from the interior base.
Len
Like Larry said all ashtrays should have burn marks. You could use epoxy I think that would hold up and you could clean it. I would use a black or clear epoxy. You could also use a wood like "hard maple" but the burn marks would look ugly.
Back in the day when it seemed everyone smoked I would see a lot of burn marks on wood tables and bars. None of them caught fire. Fire takes the path of least resistance so the tobacco will burn but the wood won't. Now I don't want anyone to lay a lit cigarette down on a wood table and go to bed.   :boo:
As stated wood will show burn marks.
Take the bowl you make, get some tine glass beads (think sand blaster), or good decorative fine sand and fill it 3/4 of the way, if you can use a dremel with a small (3/8) drum and make depressions on each side to rest the cigarette on.
Jerry, there's nothing I know of, that will stand up to the heat of the cigarette coal. It will melt and burn, and there's always the possibility of the ashtray catching fire from an unattended cigarette. The box/dish your showing is far to deep to be used as an ashtray, it should be no higher then 1 and 1/2 inch high from the interior base.Len
The only reason it's that deep is because I was thinking about telling them to put sand in it so the cigarettes wouldn't burn to the edge thanks for your help. Jerry
  Maybe you could make some wood art that says "No Smoking"  and glue it to the top...Just being a wise guy.. I was going to suggest filling it with sand too..  but really I would not use it as an ashtray. Wood is a fuel, you know... might  just use is as a desk top decoration, instead
Dick
heppnerguy
Okay I've never made one and this would be my first attempt at a bowl too, anyway someone asked if I could make an ashtray out of wood? My wife found a few but my ? Is can you seal them with anything so they don't burn?attachicon.gif20161227_172551.jpg
No real need to seal them for that... fill them with real fine dry sand and you will not have a problem.  You could put a thick epoxy coating on the upper most edge but other than that the sand will take care of most of it.
DW
