worbler Posted January 7, 2017 Report Posted January 7, 2017 So, apparently it's the year of the rooster. I found a design for this while looking on Pinterest and thought I need to do that. It's cut from 3mm MDF. I'm not sure how I'm going to finish it though. Maybe stain it dark and put it on a lighter backer. Lucky2, amazingkevin, jollyred and 4 others 7 Quote
wombatie Posted January 7, 2017 Report Posted January 7, 2017 That is very unique. You did a great job on it. Marg Quote
hawkeye10 Posted January 7, 2017 Report Posted January 7, 2017 So, apparently it's the year of the rooster. I found a design for this while looking on Pinterest and thought I need to do that. It's cut from 3mm MDF. I'm not sure how I'm going to finish it though. Maybe stain it dark and put it on a lighter backer. Tim any finish you use please try it on a scrap piece of MDF first. MDF is hard to finish the cut part will soak up stain or paint or what ever the finish is. This clock I made is MDF and I had a heck of a time finishing it. I won't be making anything else using MDF. Birchbark, amazingkevin and lawson56 3 Quote
DWSUDEKUM Posted January 7, 2017 Report Posted January 7, 2017 Excellently done. Thanks for sharing this with us. DW Quote
DukeNukem Posted January 7, 2017 Report Posted January 7, 2017 Nice pattern and cutting well done. Jerry Quote
meflick Posted January 7, 2017 Report Posted January 7, 2017 Very nice work. Hope the year of the Rooster means a good year for all! Quote
Phantom Scroller Posted January 7, 2017 Report Posted January 7, 2017 Great pattern or is it the year of the cock. Roly Quote
amazingkevin Posted January 8, 2017 Report Posted January 8, 2017 So, apparently it's the year of the rooster. I found a design for this while looking on Pinterest and thought I need to do that. It's cut from 3mm MDF. I'm not sure how I'm going to finish it though. Maybe stain it dark and put it on a lighter backer. Nice job ! Your starting out the new year right! Quote
Lucky2 Posted January 8, 2017 Report Posted January 8, 2017 Timothy, that's a nice looking sign, I'm very interested in seeing it when completed. Len Quote
Lucky2 Posted January 8, 2017 Report Posted January 8, 2017 Tim any finish you use please try it on a scrap piece of MDF first. MDF is hard to finish the cut part will soak up stain or paint or what ever the finish is. This clock I made is MDF and I had a heck of a time finishing it. I won't be making anything else using MDF. Don, as long as you seal the cut ends on the MDF with a clear coat of some sort, you shouldn't have any issues when trying to finish it. The only time I have issues with MDF, is when I don't seal the edges before trying to finish the project. The surface of MDF has a coating on it, the edges don't. The cut edges will soak up finish like a sponge, and they are susceptible to swelling if not sealed. I use Min-Wax Prestain Wood Conditioner, or a poly/varnish mix, both do a good job of sealing it. Len Quote
lawson56 Posted January 8, 2017 Report Posted January 8, 2017 Tim that is an Awesome sign. Now that I know that I will have to cut a few Roosters,Always learning here in the Village.Dan that is a Beautiful clock. Quote
hawkeye10 Posted January 8, 2017 Report Posted January 8, 2017 Don, as long as you seal the cut ends on the MDF with a clear coat of some sort, you shouldn't have any issues when trying to finish it. The only time I have issues with MDF, is when I don't seal the edges before trying to finish the project. The surface of MDF has a coating on it, the edges don't. The cut edges will soak up finish like a sponge, and they are susceptible to swelling if not sealed. I use Min-Wax Prestain Wood Conditioner, or a poly/varnish mix, both do a good job of sealing it. Len Len I did seal it with shellac. It was still a pain. Lucky2 1 Quote
lonewolf Posted January 8, 2017 Report Posted January 8, 2017 Like that design, excellent cutting. Quote
penquin Posted January 8, 2017 Report Posted January 8, 2017 That came out sweet, like it a lot. jim penquin Quote
worbler Posted January 13, 2017 Author Report Posted January 13, 2017 I just thought I'd mention something about MDF. Colouring it can be easily done with Highlighter pens and it doesn't bleed into the fibers. Even colouring the edges can be done with minimal fuss, it just applies perfectly. The only problem I can see with edge colouring is getting into tight places with the highlighter. Quote
