rjweb Posted January 9, 2017 Report Posted January 9, 2017 Good afternoon, I am cutting a photo puzzle, 5 x7, 140 pieces, yes I know I must be nuts, the puzzle pieces are small and I am using 1/4 inch poplar, finding some of the small areas are weak, what wood should I be using, I want these to last, thx RJ Quote
jbrowning Posted January 9, 2017 Report Posted January 9, 2017 Maybe 1/2" baltic birch plywood? Jim Quote
heppnerguy Posted January 9, 2017 Report Posted January 9, 2017 If I was cutting a puzzle I would be using 1/8 inch.. 1/4 inch on a large puzzle, max.. I hope you aren't sorry you asked.... Dick heppnerguy Quote
WayneMahler Posted January 9, 2017 Report Posted January 9, 2017 I was thinking something like 1/4" cherry or maple. But 1/4 BB should work as well. Quote
Lucky2 Posted January 9, 2017 Report Posted January 9, 2017 RJ, 5x7, 140 pieces? Yep I do think you're having a weak moment, but to each their own. I would use 1/4" stock for this one, it would help make the pieces more manageable. I think that with using 1/8" stock, the pieces would be to tiny. Len Quote
jbrowning Posted January 10, 2017 Report Posted January 10, 2017 Would there be any help if it was stack cut with the 1/4"? Jim Quote
Dan Posted January 10, 2017 Report Posted January 10, 2017 I would use 1/4" Baltic birch plywood. I would also make the pieces larger, between 1/2" and 3/4". That would only give you about 50 pieces or so, but the sizes would be much easier to handle. Quote
amazingkevin Posted January 10, 2017 Report Posted January 10, 2017 (edited) Good afternoon, I am cutting a photo puzzle, 5 x7, 140 pieces, yes I know I must be nuts, the puzzle pieces are small and I am using 1/4 inch poplar, finding some of the small areas are weak, what wood should I be using, I want these to last, thx RJ i've done several dollar bill puzzles with 61 pieces in 1/4" and 1/8" dog puzzles,8" x 10"- i do in 3/4" plywood and are self standing.sounds like your on the right track. Edited January 10, 2017 by amazingkevin Quote
NC Scroller Posted January 10, 2017 Report Posted January 10, 2017 I also us 1/4" baltic birch plywood for all my card and photo puzzles but I have never cut pieces that small. I use plywood because it is more stable then solid wood with less twisting and warping. Quote
rjweb Posted January 10, 2017 Author Report Posted January 10, 2017 Thx for all the good advise, I know what to use and cut down the number of pieces in the puzzles. I know a lot of you cut without a pattern, I am not that good at it yet, and I am using the patterns, Steve good patterns. Is there a site where I can generate a puzzle pattern by the number of pieces and size, thx again, RJ Quote
NC Scroller Posted January 10, 2017 Report Posted January 10, 2017 Cutting without a pattern is a lot easier then you think. I talked my self out of cutting puzzles for years until I made up my mind to "waste" a couple pictures. Look at the picture and start cutting along the edged of objects. You will get the hang of it very quickly. An you know those pictures I thought I would waste. They made perfect puzzles. dgman 1 Quote
dgman Posted January 10, 2017 Report Posted January 10, 2017 I agree with Scott above. Cutting puzzles freehand is easier, and uses less waste and time. My icon is a picture of my first ever jigsaw puzzle. I started with a piece of waste 1/4" Baltic birch plywood. I practiced cutting puzzle pieces, and after about ten or twelve pieces, I felt I was ready to cut my puzzle. Quote
Dan Posted January 10, 2017 Report Posted January 10, 2017 I agree with Scott and Dan. As you cut you will find it easier to freehand cut the pieces. Many puzzlemakers will cut figurals based on the shapes of some images. If you search these scroll saw sites you will see some amazing puzzles. If you are just getting started, glue a Christmas card to a piece of 1/4" BB ply and cuts some pieces freehand. Then do some more following and outline of a shape on the card and add the tabs of the puzzle piece. It gets fun.Enjoy. NC Scroller 1 Quote
