I know that DW is a fan of making banks for kids and i am sure some others have experience with them...I am about to make my first one and i see that there are kits available so that i do not have to cut the plastic see thru side panels myself....I wonder if this is cost effective or not ? I have never cut plastic or acrylic before and don't even know what blade is best......I would appreciate your feedback on what you bank makers do.....Thanks in advance, Steve.
Steve I made them for my grand kids a while back. I cut my own and I believe I used #5 blade. Keep the speed down on the saw so not to melt the sheet. And you have to predrill for the screws. I had 6 to make so I bought  sheet of 1/8" at the big box store and it was a lot better deal then ordering them online.
I think in general, these kinds of materials cut best with a skip tooth style blade.  The skip teeth clear the kerf better than reverse teeth, thus keeping the heat down.  If the kerf gets hot, the acrylic/plexiglass, etc will fuse back together behind the blade and make life miserable.  I cut 100 snowflake ornaments out of 1/4" polycrylic this year and a #5 skip tooth blade worked very well.  I was even able to stack 2 layers together for a total thickness of 1/2", with no melting in the kerf.  I tried using a couple different reverse tooth blades and they did not work, no matter how slowly I cut.
Steve I cut mine on the band saw. :)
For my first Bank I bought the kit from Meisel. It had all the plugs etc. Now I would cut my own. The FD polar blades cut very nicely.
This design was published in an issue of SSWWC
If you don't min. Which brand is that skip tooth blade?
Thank you
Sam
I have not cut much acrylic but I would suggest visiting sloan's. I read their ways of cutting and it went great. I cut out small ornament size humming birds, and others just go slow and I used duck tape on the acrylic without taking the paper stuck to the acrylic off. Before reading the suggestions It was a much slower cut than after I could go faster. It has been years so the techniques may have changed.
I saw your post after I saw hawkeyes and your little engine bank is really cute too. I guess I am going tohave to make a couple of banks too and see what reaction I get from them
Dick
heppnerguy
Steve,I got the thin acrylic at home Depot. Good price and it has protective paper on it.just glue your pattern right to it.I found it to cut well at slower speed.When I drilled for the screws,I placed drill bit where I wanted it and put drill in reverse for a second.That gives it a spot and keeps drill from wandering.
