I recently switched from the "entry-level" Craftsman to the DW788.  I'm finding it a little more difficult to switch out blades, but the lift-arm helps to make fretwork much easier.  I didn't realize how much I pushed my work into the blade until using the Dewalt.  I hardly have to keep any pressure on it at all.  I'm still getting used to using it, but I feel pretty good about my choice to purchase the Dewalt model.  My largest concern is blade tensioning.  I use the max-level every time...is that normal?  Maybe I over-tightened when using the Craftsman, but I'm so new at this I really don't know...
Generally speaking, more tension is better than not enough tension.  As long as you aren't snapping blades, you are probably OK, but try cutting with the tension set a little lower and see how it does.
Thanks Bill.  No breaking of blades thus far (fingers crossed).  It just doesn't seem like the "max" tension is very tight compared to how tight I set the tension on my craftsman model.
You might be surprised.  My first saw was a Craftsman.  I never seemed like I could get enough tension with it.   When I upgraded to the DeWalt, I found it was easier to apply the tension, which may make it seem like you aren't cranking it high enough, because you have a little more mechanical advantage with the cam & lever tensioning system.  Tensioning the Craftsman seemed as though took a little more effort.  Press against the blade.  There should be little deflection and if you flick it with your fingernail, you should get a high pitch ping.  Bottom line is how it cuts.
Jeff you are hooked now. I hope you enjoy your new saw. Now we need to see some pictures of your work.   :)
Good to hear you lik ethe new saw.  Takes some getting used to for sure.  i bought a foor pedal from harbor freight and really like it.
You can adjust the blade tension know itself.  You can look it up but basically you remove the know and under it you just rotate this thing and out the know back on.  Did it with mine and now i adjust to 2 max.
I would basically echo this. Have a newer Delta, but they tension the same.  I am a top feeder.  (It would also apply if you feed from the bottom.) When I clamp the bottom, I take my left fingers, insert the blade AND LIFT UP ON THE CLAMP to remove any slack and tighten the clamp.
Secondly, as crupia stated, you can remove the switch (4 screws) and remove the cam underneath.  You will see a rod pointing towards you that has the end bent up.  Give it one turn clockwise, reinstall the cam and try it before putting the switch back on.  If you still can't get sufficient tension. give the rod another turn.
Hope this helps friend.
jerry
Edited by jerry1939
Hi;
I just bought a Dewalt and I love the scroll saw. My old one is a Craftsman which I'm keeping and will use it to sand the tight spots on my projects. My tension is at about 3.5 and that seems fine for me.
Edited by rmaker
Hi;
Edited by rmaker
When tightening the blade you should pluck the blade and hear a TING sound  It should be crisp and clear when you pluck it.  I have a DW788 and when I tension it is right around 3 1/2.
DW
i hold down the upper arm when changing the blade and never set the dial past 1.5 .
Congrats on the new saw. I have been using a DW 788 for a few years. I have never needed to tension over 3.5 or 4.
Hmm...then I may have a problem.  If I don't max out the tension lever, the blade isn't tight enough.
I too hold down the upper arm to set the blade...do you continue to press down while adjusting the tension lever?  I have had to set to the maximum tension setting with each blade I put in!
You really shouldn't have to crank the DeWalt tension lever all the way to 5 to get enough tension, especially on a new saw.  The tension mechanism does wear and over time may need adjusted.  The website that Scrappile refers to will show you how to make those adjustments.  If this is a new saw, you could consider returning it.
Like others said I also lift up on the blade and push down on the top arm while changing the blade to get rid of all the slack. If I don't do that the tension lever does need to go higher. It seems automatic, I don't even think about it.
