Awesome! Where do you get these braided blanks?
Dan
Dan I have been doing my own casting. This braided material is actually some flexible water pipe I found at lowes home center. Cut the ends off and pull the hose material out and you have an out brass sleeving which I cast in clear resin after I wrap it around the pen tubes. I get some failures but most have been fairly good. I have a couple more castings and then I need to get away from pen making for awhile. I have some clocks I want to get done before summer. Thanks for looking.
  • 4 weeks later...
