This is my go to sander for just about any project I ever do. All my scrollwork 220 grit paper and I am done.
www.amazon.com/PORTER-CABLE-330-Speed-Bloc-Sheet-Sander/dp/B0000222Y9/ref=sr_1_1?s=hi&ie=UTF8&qid=1488856522&sr=1-1&keywords=porter+cable+330+sander
Edited by JTTHECLOCKMAN
Hey Dave, I suppose you could trim off the excess with a sharp X-Acto knife. I haven't tried it yet, but I will next time.
Dan, Dave's not looking to remove extra sanding paper, he's wishing the sanding paper was larger so that it would curl up over the edges.
Len
Len
Yes Len, I understand that, but if the disk was trimmed down, it might not catch. It was just a though. I'm going to give it a try next time I'm ready to sand something.
After I am done cutting a project I run over it with an orbital sander with 220 grit. Would be nice if the sander had a pad that had the edges tapered up with the paper rounded up so the edges wouldn't catch on the cut wood. You wouldn't think that would be hard to do. dave
Maybe you could add a sponge spray glued to the sander base and then bigger paper to go around it .i have self sticking sander base like Velcro.i just leave a Velcro piece of sand paper on spray glue what ever i like to it and don''t have to buy expensive sand paper from here on out.the sponge should work out great for you
They do. My Makita palm sander is made like that.
theres a thing called an interface pad used in autobody for sanding. its basically a foam pad with H&L on both sides to slap on the sander then slap the sanding disk on the other side. im wondering iffen it might help sanding fretwork.
aaaaaand I can insert a link!
but I also use 6" discs on my 5" sander and it works pretty good.
this, I assume, if you are referring to getting rid of any fuzzies from cutting.
Rusty, What model makita do you have? Orbital or sheet? Does it catch on your fret work? dave
The model number is B04510. It is an older sander. I have had it 30 to 35 years. I sand all of my fretwork and any other wood project and have never had a problem.
I guess I am the oddball in the group.... For all my finished pieces I sand both sides with a Mouse sander, various grits depending on the project. I've never had a problem with pieces breaking....
for shaping and fine tuning pieces for clock assembly I have an 6 inch belt sander with a 9 inch disk on the side. I also have a 1 inch belt sander with a 4 inch disk and a spindle sander for shaping
I am probably a it unconventional in the way I do things but I am self taught and I guess it works for me....
