My brother and I are firefighters, and getting on, me being 59 and him being 53, so when I saw this cartoon I had to see where it would lead me.
This is the actual cartoon I got off Pinterest.
Then I burned the cartoon.
Still not too happy and not knowing how to do much with a one dimentional drawing, I cut out the drawing and will stick it to the white board and place red tape around the edge.
Still not too happy, I decided to make a spray template.
Now my plan is to use spray on 'snow' to leave the cartoon on windows and walls. I stack cut this in thin plastic so I can give him one and then we will put these around our own stations when we know we are not being seen and just listen to the crews wonder who is doing it.
Edited by savethebeer
I tried placing the photos in the correct order and even embedded the photos in the correct order so I don't know why they entered in the wrong order.
# 1 is the cartoon. # 3 is the burnt one. # 4 is the cut out drawing and # 2 is the spray template.
Bob
Very nice work! Good intentions,Don't forget you can use the cut outs as a template for spray on tee shirts.I've done this many times to make special tee shirts.
One of the things about belonging to the village is the sense of belonging, and to be able to put some new ideas out there for all to comment. I did not think this was suitable for Bragging Rights as I considered the above to be only a 'throw away' idea, which I did not put too much time or effort into when cutting it out nor have I finished # 3 or # 4.
I thank you all for the comments and I thank Travis and the other mods for the upgrade.
Bob
stack cut from cut stock    you may cut 20 at once      Paint as needed and have a blast with the guys      also  can use it as a maget        Jerry        PS LOOKS GREAT
