NiTay614 Posted March 31, 2010 Report Posted March 31, 2010 I have been working on Uncle Sam whirligigs. I took one outside this afternoon and discovered the base is not heavy enough to enable the whirligig to remain upright. Presenty it rest on a 31/2 x 31/2x 2 inch block that is secured to a 3/4 x 6 x 6 inch piece. Any suggestions would be appriciated. He is fasten to my deck railing at the present time with a quicky clamp. Thanks Quote
merlin Posted March 31, 2010 Report Posted March 31, 2010 If it was mine I wood attach it with a bracket attached to Uncles leg to that there post. Raise it up the post so the blades clear the top. My 2 NZ cents worth. Merlin Quote
NiTay614 Posted March 31, 2010 Author Report Posted March 31, 2010 I am not attempting to attach it to the deck railling. I made the whirligigs with the idea of selling them. I do not want them to topple over in someone else's pocession. I guess I am asking if anyone knows how I can make them more stable, say if someone wanted to place it ina flower bed. Quote
Kepy Posted April 1, 2010 Report Posted April 1, 2010 Whirligigs are designed to be mounted. I don't think you could make them free standing without tipping when the wind blows. Quote
edward Posted April 1, 2010 Report Posted April 1, 2010 I have made Whirleygigs before, and what I do is use fiberglass rods about 2" long and drill a hole in the bottom of the whirleygig and insert the rod into the bottom, and I used a pressure treated railing upright and drilled a hole in the center of it and used a plastic insert to hold the fiberglass rod. These parts can be purchased at Misel hardware, hope this helps. The stakes can be purchased at H D or lowes. Edward Quote
NiTay614 Posted April 1, 2010 Author Report Posted April 1, 2010 Thanks Edward, that was exactly what I was gearing toward. I purchase a bracket today which I hope will solve the problem and permit me to retrieve my quicky claps! Quote
