Last year I purchased an older RBI Hawk 214.  It is much easier to use than the Skil I already had, but recently, the RBI hawk was causing circuit breakers to flip when ever the cord was bumped.
I inspected the cord and connections carefully and could find nothing wrong.  Then with a continuity tester started checking things and found the cord was somehow shorting out.  The exterior black coating was still soft and pliable.  So I cut the cord length wise at one spot.  The plastic coating on the interior wires was hard and brittle and was crumbling to pieces letting the hot, neutral and ground wires contact.    Checked at two more spots, inside the outer black covering the plastic coating on the individual wires had disintegrated into a gritty powder.
I already lost one house and shop to fire.  Don't want another fire.  I replaced the cord with a new shop cord this afternoon.
Edited by zimmerstutzen
That was a blessing in disguise finding the problem !
You brought up a good safety measure. Older cords CAN and DO become brittle over time and cause the problem you discovered. Glad you found it before something serious happened to your shop and family.
Old Scrollers become brittle and cause problems as they get older too............ :razz:
