Trka2002 Posted April 1, 2017 Report Posted April 1, 2017 Good morning, Now that there are two scroll saws in my shop, I am looking to get another foot control. The one I have know is just on/off and I'm looking for one to control speed. Does anyone have any good recommendations? Thanks, Troy Quote
WayneMahler Posted April 1, 2017 Report Posted April 1, 2017 The ones I have in my shop are on/off. Don't know of any that control speed too. Quote
Scrolling Steve Posted April 1, 2017 Report Posted April 1, 2017 I think Wayne is right...mine is on/off as well ! Quote
hawkeye10 Posted April 1, 2017 Report Posted April 1, 2017 The foot controls I have seen either turn it on on or off or another kind you have to hold it down with you foot, if you take your foot off the saw stops. They do make variable speed controls for routers that don't have variable speed control. That may or may not work with a scroll saw motor. I don't know. Quote
NC Scroller Posted April 1, 2017 Report Posted April 1, 2017 You CAN NOT use a variable speed foot control on a scrollsaw unless it was designed specifically for your saw and model. Else you will burn out your motor in very short order. You can only use on of the on/off types. Lucky2, GrampaJim and Scrolling Steve 3 Quote
ike Posted April 1, 2017 Report Posted April 1, 2017 I have never seen any thing like you are asking for. IKE Quote
dgman Posted April 1, 2017 Report Posted April 1, 2017 You CAN NOT use a variable speed foot control on a scrollsaw unless it was designed specifically for your saw and model. Else you will burn out your motor in very short order. You can only use on of the on/off types. Listen to Scott!!! Quote
David Lehner Posted April 1, 2017 Report Posted April 1, 2017 95% of the time I am standing when I saw. The regular foot control (which I now have 2 of and don't use) is more for use when sawing while sitting (in my opinion) .. I bought a foot switch through Amazon... it is about 4 1/2 X 3 1/2 inches and only 1 1/2 inch high.... works better for me than the pedal foot controll Quote
JTTHECLOCKMAN Posted April 1, 2017 Report Posted April 1, 2017 (edited) The statement of do not use VS with a VS motor is correct. Some people tried using a sewing machine foot pedal and they burned the motor up. A word to the wise do not do it. There is actually no need for it. You do not vary the speed as you cut. Need to vary speed use the dial meant for this. Stop and think about how tiring that would be trying to hold steady a certain speed with your foot. Does not make sense in scrolling. Edited April 1, 2017 by JTTHECLOCKMAN Lucky2 1 Quote
Scrappile Posted April 1, 2017 Report Posted April 1, 2017 (edited) Well, I can see where it would be a nice feature, to be able to control the speed with a foot pedal, but I have never seen one that does. I don't understand how it would work with a VS saw. Would you disconnect the VS control switch on the saw or turn it to full speed and hook the foot switch after it some how?? I mean, John, there is actually no need for a foot switch, there is an on and off switch on a saw also. Anyway, unless it is specific to my saws,,, I would not think of trying it. Motors are expensive. Dave, is you switch a "dead man' which the you have to keep you foot on to run your saw, lift you foot off and it quits? Or the toggle on and off type that step on turn it on, step on again turn it off? I would think the latter would work best for standing. Edited April 1, 2017 by Scrappile Quote
amazingkevin Posted April 1, 2017 Report Posted April 1, 2017 I agree with all of the above! Well, I can see where it would be a nice feature, to be able to control the speed with a foot pedal, but I have never seen one that does. I don't understand how it would work with a VS saw. Would you disconnect the VS control switch on the saw or turn it to full speed and hook the foot switch after it some how?? I mean, John, there is actually no need for a foot switch, there is an on and off switch on a saw also. Anyway, unless it is specific to my saws,,, I would not think of trying it. Motors are expensive. Dave, is you switch a "dead man' which the you have to keep you foot on to run your saw, lift you foot off and it quits? Or the toggle on and off type that step on turn it on, step on again turn it off? I would think the latter would work best for standing. The statement of do not use VS with a VS motor is correct. Some people tried using a sewing machine foot pedal and they burned the motor up. A word to the wise do not do it. There is actually no need for it. You do not vary the speed as you cut. Need to vary speed use the dial meant for this. Stop and think about how tiring that would be trying to hold steady a certain speed with your foot. Does not make sense in scrolling. 95% of the time I am standing when I saw. The regular foot control (which I now have 2 of and don't use) is more for use when sawing while sitting (in my opinion) .. I bought a foot switch through Amazon... it is about 4 1/2 X 3 1/2 inches and only 1 1/2 inch high.... works better for me than the pedal foot controll Listen to Scott!!! I have never seen any thing like you are asking for. IKE You CAN NOT use a variable speed foot control on a scrollsaw unless it was designed specifically for your saw and model. Else you will burn out your motor in very short order. You can only use on of the on/off types. The foot controls I have seen either turn it on on or off or another kind you have to hold it down with you foot, if you take your foot off the saw stops. They do make variable speed controls for routers that don't have variable speed control. That may or may not work with a scroll saw motor. I don't know. I think Wayne is right...mine is on/off as well ! The ones I have in my shop are on/off. Don't know of any that control speed too. Good morning,Now that there are two scroll saws in my shop, I am looking to get another foot control. The one I have know is just on/off and I'm looking for one to control speed. Does anyone have any good recommendations?Thanks,Troy I agree with all of the above! Quote
meflick Posted April 1, 2017 Report Posted April 1, 2017 (edited) Both Judy Gale Roberts at Intarsia.com and Ray at Seyco sell foot control switches. https://intarsia.com/collections/hardware/products/foot-switch and http://seyco.com/fs-3-universal-15-amp-foot-switch/ However, I had previously purchased one from Amazon before I got started and found either Judy's or Seyco's site. The second used saw I bought came with the saw. Mine is the saw is "on" and running while stepping on it and stops immediately if I lift my foot. I much prefer using the foot pedal while sawing and use it both when I sit or stand at the saw. As noted, you control the speed with the variable speed knob on the saw its self. Edited April 1, 2017 by meflick Quote
blights69 Posted April 1, 2017 Report Posted April 1, 2017 I do not like peanut butter I know that has nothing to do with the foot switch question but as there has been so many answers to that question I thought I would write something and this is the first thing that came into my head Frank Dave Monk 1 Quote
AK Moose Nugget Posted April 1, 2017 Report Posted April 1, 2017 C'mon Frank....crunchy PB is da BOMB!!! As to the question, I use an on/off foot pedal as well. blights69 1 Quote
hawkeye10 Posted April 1, 2017 Report Posted April 1, 2017 Here is a foot pedal and it's on sale. $20 and free shipping. It's the second pedal on the page. The first one I don't believe you would like. https://www.mlcswoodworking.com/shopsite_sc/store/html/ec170317.html?zoom_highlight=foot+control+switch Quote
OCtoolguy Posted April 1, 2017 Report Posted April 1, 2017 If I'm not mistaken, Harbor Freight has both kinds. I bought an on/off one but I can see why you might want to have one that regulates speed/power. Sort of like the foot pedal that sewing machines use. Quote
bandaideman Posted April 1, 2017 Report Posted April 1, 2017 "I do not like peanut butter" Now that's a good quote Frank blights69 1 Quote
tuner Posted April 2, 2017 Report Posted April 2, 2017 Your all all most right😂 most units will not except vs but if you have a external motor belt drive like some of the older excalibur you can add a 1700 r p m moter that will convert to vs. as far as a foot control will it's not like your car were have inches of play to get and hold your speed, no doubt it would work ... But.. Quote
JTTHECLOCKMAN Posted April 2, 2017 Report Posted April 2, 2017 If I'm not mistaken, Harbor Freight has both kinds. I bought an on/off one but I can see why you might want to have one that regulates speed/power. Sort of like the foot pedal that sewing machines use. Do not do it. Please give me one example where you would need to change speed when you started cutting. Never come across a situation and I have cut many materials. Change speed before you start not while you are cutting and how do you hold that exact speed as you cut??? AK Moose Nugget and OCtoolguy 2 Quote
Scrappile Posted April 2, 2017 Report Posted April 2, 2017 John is correct. Two types are toggle on and off and the deadman where you keep you foot on the pedal to keep it running. That is the kind I prefer but I don't scroll standing. I do adjust speed fairly often when doing delicate fret work pictures. There are places I need to go slow and then speed back up. It would be nice to be able to do that with foot control like you can do with a sewing machine, but I would never try it with any pedal unless it was specifically designed for the saw. I like my saws too much. OCtoolguy 1 Quote
OCtoolguy Posted April 2, 2017 Report Posted April 2, 2017 Do not do it. Please give me one example where you would need to change speed when you started cutting. Never come across a situation and I have cut many materials. Change speed before you start not while you are cutting and how do you hold that exact speed as you cut??? I agree with you 100% JT, I was just trying to give an answer to the OP's question. I use a foot pedal with just the on/off option. Quote
stoney Posted April 2, 2017 Report Posted April 2, 2017 Like has already been pointed out by others DO NOT connect any type of variable speed control to a scroll saw unless it is designed specifically for that saws motor. Varying a motor speed differs greatly depending on motor type. I only want to have to replace a motor if it fails from normal wear and use. Quote
David Lehner Posted April 4, 2017 Report Posted April 4, 2017 (edited) 95% of the time I am standing when I saw. The regular foot control (which I now have 2 of and don't use) is more for use when sawing while sitting (in my opinion) .. I bought a foot switch through Amazon... it is about 4 1/2 X 3 1/2 inches and only 1 1/2 inch high.... works better for me than the pedal foot controll This is the pedal I use on my Dewalt and Excalibur saws... have been using this pedal for 6 - 7 years Available in Amazon for about $23.00 Edited April 4, 2017 by The Scroll Troll Quote
Jim McDonald Posted April 4, 2017 Report Posted April 4, 2017 I've got a deadman switch from Harbor Freight about six years ago and it has never given me a second of trouble. Quote
Grumpy Old Bear Posted April 5, 2017 Report Posted April 5, 2017 (edited) Even though I have only made one other post, I have done quite a bit of cutting, while sitting. When I first started I would break blades rather quickly, since I was self taught without the aid of the internet. I found the deadman switch to be a very helpful tool. when the blade would break my natural instinct was to jump, thus pulling my foot from the switch. I don't know if that helped save wear and tear on the saw, but it made me feel good not to hear the saw clanking with no (one piece) blade installed. I hope this helps. Jim Edited April 5, 2017 by Grumpy Old Bear Quote
