I have a Dewalt Scroll Saw DW788 and it will not turn on... I bought the saw about 6 years ago and already had the motor replaced a couple of summers ago but rarely used the saw last year... the last couple of days it would run, then not turn on... wait awhile then it would run, then not turn on...it didn't quit as long as it was running just when I went to turn it back on... the fuse looks fine (after the major aggravation of trying to get to it !!)... I removed the switch casing and blew it out with canned air but I didn't disconnect the wires.. I wasn't sure how to do that since I couldn't really reach into the casing... I went ahead an ordered a new switch just in case because the nearest Dewalt repair store is over an hour away... any other suggestions?  and could someone tell me how to replace the switch when I get it ? there must be an easier way to get to the wire plugs... If it is the motor again, I just don't know what to do.. am I throwing good money after bad ?
Can't help much but don't get too frustrated it sounds like a loose connection or a switch. a dead motor will not start up again so you should be OK there, hopefully someone who knows the 788 will point you in the right direction, mean while if you haven't, check your wires, plug, even the house plug don't think you will find anything but it can't hurt, good luck
If my memory serves me correctly, (and many a times it hadn't). I had the same problem with my 788. It would work intermittently. That's when I went with the foot switch. Then after awhile, it quit all together and I had to get a new motor. Hopefully, all's it is, is the switch. Good luck and keep us posted.
It sounds like the motor, lets hope not because they are expensive. The motor is a brush type and when the brushes ware they put off dust and they get into the armature and short out . These motors don't have any vent holes and there is no escape for the dust, With other motors of f this type i have taken them apart and cleaned the armature slots with a file being careful not to short out the windings. I have had mine for 3 years and had to replace the motor,
IKE
Edited by ike
More than likely, it is the switch. It is not sealed, so dust and debris will eventually gum up the contacts in the switch. I have many times taken the switch apart, and cleaned the contacts. It has always been the issue.
I teach scroll saw at the local Woodcraft store and have had a saw quit working in mid class. I can take the switch apart and working in about ten minitues.
To remove the switch, first unplug the power cord, then remove the 4 torx screws holding the control housing to the saw. With long nose plyers, pull the two wires off the switch. Pull from the wire conectors.You also have to disconnect the conector coming from the speed controller. Once you have the housing removed look inside. You will see two clips holding the switch in place. Use a screw driver or your fingers to squeeze the clips towards the switch, then push the switch out! To replace, reverse the process.
Good luck!
Gosh,I,ve wore out 8 dw788'a and never had an issue with a motor???
